Overdrive...changes I should notice
I just realized after reading my owners manual that I've been driving in 4th gear instead of the "D" gear all the time since acquiring my '98 gs 300 two weeks ago.
Now that I will drive in the "D" gear from now on what, if any changes should I immediately notice?
Car drove pretty nicely in 4th. I understand "D" gear uses overdrive while 4th doesn't.
What does this mean in layman's terms?
Thanks in advance for any feedback.
Scrim
Scrim
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
It simply means you never shifted into fifth gear.
You'll notice at speeds (probably > 40mph under normal/light accelleration) that the car is quieter and you'll get slightly better gas mileage.
On the highway, you'll feel less 'lugging' if you take your foot off the gas if you're going over 60 or so.
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
:eek:
Forum Administrator
Originally posted by mooretorque
Dave, I think you mean "engine braking" when you say "lugging"; lugging refers to the phenomenon that occurs in a manual trans car that is going too slow for the gear it is in and the tranmission is trying to drive the engine, rather than vice versa.....sounds like knocking, car will start to jerk slightly. Not good for the motor, obviously.
:eek:
:eek:
Originally posted by DaveGS4
Yep, you are correct Dr M! Sorry, lugging was on my mind - I test drove a new M3 SMG and it had some serious lugging issues at a couple of lights. Cool car though.
Dave,
you mean the test driver of the M3 had some serious lugging issues (meaning he didn't downshift)?
Or did you drive the car in the automatic mode?
Forum Administrator
I was driving the car and it was in automatic mode. Pulled off from a light, slowed down a bit and the car went nuts... like a frikkin bronco that had been stuck with a hot poker. I thought I was going to lose a filling!
My GF (who is thinking about getting one) had driven the car the previous weekend and the same thing had happened to her. Dunno, the dealer acted like "what, I didn't notice anything"![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
now.... back to our regularly scheduled overdrive thread
so my question is.....
under what circumstances would I want to switch gears from "D" to "4"?
when I want to pass someone on a one lane highway with a semi truck coming from the other direction perhaps?
thanks,
scrim
thanks,
scrim
Forum Administrator
thanks,
scrim
thanks,
scrim
IMO you should leave it in 'D' nearly all the time. Typically the only time I shift into another gear is when I'm going down a long grade and want to use the engine for braking.
I also will shift to '3' on the highway when I think I might get into a race with an upcoming or about-to-pass car so I don't have to wait for the shift town. I use my e-shift (don't think you have this on your year GS3).
thanks,
scrim
thanks,
scrim
Originally posted by jaymode
I also use downshifting when running on slick roads, so i do not have to brake as much. It helps slow the car down without losing a lot of traction. I just used it tonight, cuz of the snow. Also if your speeding and you see a cop but dont wanna use your brakes, you can downshift to slow down.
I believe....
4th gear is a 1 to 1 ratio...
5th gear (or overdrive) is a higher ratio than 1:1.
You'd want to use it only at freeway speeds to help conserve gas.
Hope I didn't restate anything obvious???
Tim
Tim
and if u REALLY need to slow down, there is always the parkin brake....
but that can get scary at times.
Just a couple of things to think about............
