Toyota dealer pushing injector cleaner
Old 09-07-13, 06:42 PM
MattyG
MattyG's Avatar
Best way is to let your tank get near empty and then put in a bottle of the stuff at the gas pump. Then fill up. This is to help the Techron mix properly with your fuel.
Old 09-08-13, 02:28 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Originally Posted by LuxuryGS3
I've heard mixed things about when to add this to your tank.. I've read after you fill up or put it in on half tank or an empty tank THEN fill up as soon as you put it in,so what is the correct process in doing this? I always added it after filling up my tank.
the directions say poor the cleaner in a near empty tank then fill up. this mixes the cleaner in the gasoline .
Goko, thanks for the PEA tip. didn't know about that
Sent from my iPhone using IB AutoGroup
Old 10-02-14, 03:04 AM
kit cat
kit cat's Avatar
Have any of you guys with high miles (like 200k+ miles, preferably on a GS4) used this Chevron Techron FI Cleaner? If so, what were the results? I am considering this but a bit worried with my high miles.
My car:
GS400, 250k miles,
Long term fuel trim is a bit a high (+15%) for both banks
Short term fuel trim is I think in normal range (+/- 5%) for both banks.
Fuel trim absolute variance bank-to-bank is always less than 5%, if that.
Current Condition: Reason I am considering injector cleaner is because my LTFT trim is consistently a bit high but STFT is mostly within a normal range; so I think the car is constantly needing 15% or so more fuel and making minor adjustments. This is also reflected on my mpg; currently at about 16-18 mpg mixed city/highway when I usually have been getting around 20 mpg. I record every gas fill up and track mpg as a way to keep an eye on the car's health. Also, I have a 3.76 final drive so mpg might a bit lower than most. Recent drop in temperature has not affected my mpg and has been like this even when it was warmer (in the midwest) a few weeks ago.
What I have done so far: Cleaned TB, MAF, checked/replaced vacuum hoses, checked exhaust leaks, replaced some exhaust gaskets that looked worn, checked all O2 sensors voltage and shows that normal wavy curve (and O2 fuel trim reflects that of the STFT), etc, reset ECU but I cannot get the LT fuel trim to go down. Still not sure if LTFT is stored or deleted by disconnecting battery though... (yeah, I know, watch it just be the LTFT stored in memory that needs to be cleared lol).
I might shooting blindly but my next guess was dirty injectors. Dirty/older injectors, output is not as great, injectors working overtime, higher LTFT, lower mpg.... so clean injectors is my thought process. If anyone has tried this Chevron Techron FI Cleaner (or other brand please specify), I would really appreciate any input. Thanks in advance.
Last edited by kit cat; 10-02-14 at 03:08 AM. Reason: added that FT is consistent bank to bank...
Old 10-02-14, 11:04 AM
GSteg
GSteg's Avatar
Doesn't really hurt to use fuel injector cleaner in your car. Chevron Techron (avoid the pro-guard version), Redline SI-1, and Gumout (has to be Regane) are all good. They have PEA which is the effective ingredient you're looking for.
Old 10-02-14, 02:27 PM
vijayn
vijayn's Avatar
Hey bud,
LTFT is what gets stored in the memory banks of the ECU so yes it would stay there every time you turn ignition off and then on but you can erase it by removing the battery terminal for 5 mins or so and press on the brake pedal to dissipate any capacitors charge, after that reconnecting it. LTFT learns off of the STFT during closed loop operation.
STFT is a real time fuel trim and changes to what the oxygen sensor is doing during closed loom operation and that doesn't get stored.
If you have a +15% LTFT that means your fuel system was running lean and the ECU commanded the Fuel injectors to open +15% more pulse width to compensate to get back to the stoichometric value (14.7:1) fuel ratio for emissions.
Check the voltages on the oxygen sensor again and see if the pre cat oxygen sensors are going up to around 0.8 - 0.9V when you quickly do a sudden acceleration.
Old 10-02-14, 08:11 PM
kit cat
kit cat's Avatar
glad to hear from you, always trusted your posts
Originally Posted by vijayn
Hey bud,
phew, glad I am somewhat understanding these OBD2 parameters. So LTFT does get cleared after disconnecting the battery... Then what I don't understand is how my LTFT can build up when the highest STFT I have been seeing is +5%... maybe there's spikes so quick that my OBD2 reader isn't refreshing quickly enough to see it (but it's not showing up on the logged data either). I figured my injectors are just old and inefficient so the ECU is pushing up the fuel trim to maintain stoich.
And thanks for the advise on the upstream O2 voltage reading under acceleration... are you thinking the ECU is incorrectly adding fuel even when the O2 is sensing it's running rich?
Old 10-02-14, 08:13 PM
kit cat
kit cat's Avatar
PS: I disconnected the battery and cleared the LTFT today (verified both banks ST and LT FT are at zero % at idle after I re-connected battery) but its back up to 15%ish after a few miles of driving. I noticed that the ST and LT FT increases when idling at a stop light or even when crawling during traffic... Time to go do some more research.
Old 10-02-14, 11:56 PM
vijayn
vijayn's Avatar
Oh good, to me it definitely sounds like its compensating for a lean mixture then.
Yes your right the learning of the LTFT will only happen during warm idle and light - medium throttle (cruising - closed loop). But the value that its learnt will apply all the time not only in closed loop.
Its common after high mileage engines to slowly have deteriorating oxygen sensors, so they may put out the wavy type signal but they are only cycling from maybe 0.1V to 0.4V when they should be cycling from 0.1V to 0.9V (during closed loop).
Doing the voltage test to see if it goes up to 0.8V- 0.9V will tell you whether the oxygen sensors are the problem. If they are fine then there might be a leak after the MAF sensor or MAF sensor is reading lower voltage than normal because its contaminated with oil - but you have already cleaned it aye?
When was the last time the fuel filter was changed? It could be partially clogged. And yeah the injectors could also be clogged so putting some inj cleaner will hopefully clear some of that. - I highly recommend taken them out and getting them cleaned with a ultra sonic cleaner though as this way you can physically see them before and after visually. And also you can just change all seals/o-rings and filter baskets at the same time.
Old 10-03-14, 08:39 AM
brainsurge
brainsurge's Avatar
an increase in short term fuel trim can also be caused by a leak on the intake manifold. has recently been work performed in that area? after i changed a knock sensor on my gs 430 i had a leak on the intake manifold and checked the short term fuel trim. when i fixed the leak it was gone. but it was more than 15%, i had more like 25-35% st ft.
Old 10-03-14, 07:10 PM
Lukas99GS
Lukas99GS's Avatar
http://youtu.be/gg9ppeUMpK4
Try this out, it worked well for me. But he also mentioned chevron techron as also being good as they both use pea, I noticed a smoother idle, and acceleration at low speeds
Old 10-05-14, 07:39 AM
kit cat
kit cat's Avatar
hooooooly crap, this dude needs to decaff coffee... and his video has more angle changes than billy mays. thanks for the video though, was actually helpful and entertaining.
Old 10-05-14, 07:50 AM
kit cat
kit cat's Avatar
Great advise again, I'll have to look into that. I knew the O2 voltage should make that wave graph but didn't know it should be within 0.1 - 0.4... I have changed my O2 sensors but I'll have to look into it... who knows, maybe my ECU was erroneously forcing to run rich and slowly killing the O2 sensors again.
And yep, MAF sensor was recently cleaned.
I actually haven't replaced my fuel filter yet... I'll have to look into this also. But yeah, before ultrasonic cleaner, I'll probably grab a bottle of injector cleaner and see if that'll help since I drive my GS every day.
I've been looking for leaks after the MAF / before the o2 sensor, but without a smoke machine, it's been hard. No recent work done around the intake manifold. I know there is a formula to calculate the proper vacuum or whatever you should have for the intake manifold (I think it's the intake manifold pressure from the OBD2 parameter) but haven't gotten around it.
My LTFT has creeped up to the low 20% but I've never seen my STFT get that high... hopefully it's just something stupid.
Thanks for all the advise everyone .
Old 10-05-14, 12:27 PM
vijayn
vijayn's Avatar
[/QUOTE]Thanks for all the advise everyone .[/QUOTE]
Thats cool mate, hopefully you fix your problem. The other problem it could be is the fuel pump is stating to deteriorate - this would also make your power/acceleration decrease too.
Old 10-05-14, 11:37 PM
kit cat
kit cat's Avatar
I've been monitoring my O2 today and it's been cycling as low as almost zero and all the way up to 0.8 something volts so I'm going to rule out the O2 for now...
I bought a 2 bottles of Chevron Techron FI cleaner so when my gas gets low next, I'll try adding this to my gas tank.
Also have been looking into clogged fuel filter and started looking into parts. Hopefully it's just the filter and not the pump...
Old 10-05-14, 11:40 PM
kit cat
kit cat's Avatar
By the way, are you guys using the Chevron Techron FI Concentrate Cleaner?
http://shop.advanceautoparts.com/p/c...5740/7080568-P
There was also a Chevron ProGard Fuel Injector Cleaner, which I didn't get since it didnt say Techron but just wanted to make sure.
http://shop.advanceautoparts.com/p/c...system+cleaner
Quick Reply: Toyota dealer pushing injector cleaner
