Changed my AC and Radio display color
#66
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Here is the red display.. Although in the pics it looks orange.. it is not orange. It is RED..... For some reason.. it comes out that way. Lemme know what you all think...
Rock
Rock
#69
Originally posted by BananaGS
1)I took both stock non-nav and nav unit apart for my nav conversion project. What light you want to change if you have a nav system? I don't see what you can do with a nav system.
2)
The radio screen is transparent (non-nav unit), the light behind the radio screen make the color, changing the light or the bulb jacket will change the display light for the radio screen.
There is no screen on the nav unit, except the main LCD nav screen which you "don't" want to touch it.
2)
1) I was talking about the buttons around the NAV unit. every button like the A/C, the map, etc. i was thinking about changing them to white or light blue, but when I took the NAV unit out from the dash i couldn't pull the cover off from the unit. seems like alot of things are attached.
even until today i still want to try to take the nav face off. I want to do something with the face only
2) when I checked some japanese guy's Aristo, his A/C and radio screens are lit by cathode tubes. he changed them to white tubes and the screens turn white. I guess US GSs use just lightbulbs?
#72
Rock, was it easy to change the ignition light to red? This would be the only mod I would consider since I have the navigation and the dash is already very bright. Also, in your response to the floor light (in red) you stated "boots" what is this? a type of bulb?
Thanks,
rocklings
Thanks,
rocklings
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#75
what exactly are you using? led's or bulbs and rubber boots over the bulb or both? if led's -which ones...and does anyone know where to get cathode tubes from that we could mod into our sc's?
