Changed my AC and Radio display color
Old 02-16-09, 08:32 AM
  #121
Frankdorn
Frankdorn's Avatar
Is it this from Fry's?
http://shop4.frys.com/product/535170...H:MAIN_RSLT_PG
They're the only white LEDs in a strip from Fry's I could find.
Old 02-16-09, 10:12 AM
  #122
LeXaNoMicS
LeXaNoMicS's Avatar
Old thread !!! Reserectors !!!!
Old 02-16-09, 03:58 PM
  #123
FinLIFE
FinLIFE's Avatar
I still need couple of these tiny bulbs replaced around my tape deck..my dash is white/green now
Old 02-16-09, 04:43 PM
  #124
Frankdorn
Frankdorn's Avatar
I gathered these snippets of info:
  • 560-680 ohm resistors might work...?
  • From a 110V circuit board: 1.5 ohm resistor kept a 3V LED running at 2.96V.
  • Make sure your replacements for the LEDs are also powered by 3V DC and that your replacement for the bulbs is ready for 12V DC (so, make sure you use the correct resistor so that whatever LED you use is happy constantly at 12VDC).
  • Also - here are the problems u will encounter
    • 1) Some stuff runs on 12V, some runs on 3V. 3V u can directly stick these LEDs in... anything that previously was using an LED is 3V off the bat, so that's easy. The bulbs are all 12V powered - so u need some resistors. The ones for these LEDs are 1.5K ohm, those are mega cheap, if u need me to provide the LEDs i can include those.
    • 2) The buttons on the AC are tricky - when i made my own LED replacements, i made them the same size as the original LEDs and this was not a good idea. You shold make them smaller and find a way to fit hte LEDs inside the plastic tunnel thing... you'll see if you try. If they stick out, they make the button harder to press and sometimes might even make the button not functional all together. This only affected me on one button luckily, but if I were to do it again, I'd keep that in mind ahead of time to ensure same-as-stock operation.
  • Also, rememebr stock bulbs work in both polarities while LEDs only work in one (the negative and positive must be oriented the right way). there's a 50/50 chance for each LED that it could be wired backwards. You'd have to see which ones are not illuminating and have them reversed.
http://www.oznium.com/plcc-2
http://www.oznium.com/corvette-c5-led
http://www.v-leds.com/Shop/Control/Product/fp/vpid/6298403/vpcsid/0/SFV/32481
http://superbrightleds.com/instrument.html
Old 02-16-09, 05:55 PM
  #125
McKrevice
McKrevice's Avatar
cool. If my dash lights burn out I will follow this to fix them.
Old 02-16-09, 08:00 PM
  #126
ICECOLD
ICECOLD's Avatar
Old 02-17-09, 03:26 AM
  #127
Baliztik
Baliztik's Avatar
Anyone in Cali techie enough to get this done?
Old 02-17-09, 07:23 AM
  #128
JDM _GS3
JDM _GS3's Avatar
haha good stuff man!
Old 02-17-09, 07:30 AM
  #129
kamlung
kamlung's Avatar
https://www.clublexus.com/forums/4260275-post31.html
just done yesterday... i think the radio is more of a PITA though... the hot spots aren't too bad... i sanded down the LEDs as much as i could... but i can live with it...
Old 02-17-09, 09:21 AM
  #130
Frankdorn
Frankdorn's Avatar
Not bad!! The hot spots you mention may be due to the LED's viewing angle? I unno.
What did you use for LEDs and resistors? Where did you find 'em?
Old 02-17-09, 10:31 AM
  #131
kamlung
kamlung's Avatar
https://www.clublexus.com/forums/4260270-post30.html
i had a ton of leftover LED's from when i did my TL... i got a bunch of 5mm and 3mm off of ebay... then i filed the top of the LED flat in order to help disperse the light... i forgot to file one of the LEDs and when i put it in it was really bad like a spot light...
the radio ones are a pain in the @$$ because they are surface mounted LEDs...
Old 02-18-09, 05:39 AM
  #132
Frankdorn
Frankdorn's Avatar
What are the voltages of your LEDs and the ohms of your resistors?
Old 02-18-09, 06:21 AM
  #133
kamlung
kamlung's Avatar
i'll have to check tonight... i don't remember since i bought them in bulk on ebay a while ago when i did the LED dash conversion for my TL...
Old 02-20-09, 08:59 AM
  #134
Frankdorn
Frankdorn's Avatar
This is what I'm thinking I'd use in all locations for consistent birghtness and color temp: http://www.oznium.com/plcc-2 These run on 3V.
Twist sockets: resistors needed. Am I correct?
Surface-mounts: on the circuit boards themselves (rocker buttons, etc.) need 1.5K ohm resistors?
Existing LEDs: run on 3V, so these are a direct swap (i.e. no resistors required).
Old 02-21-09, 05:02 AM
  #135
Frankdorn
Frankdorn's Avatar
So I've come up with a roughly 470 ohm resistor needed to pull 12V down to 3V for the LEDs. All set here.
Last question: do I need resistors for the LEDs mounted on the surface of the radio's circuit board? I'm not sure if this area is a 12V or 3V feed.
Quick Reply: Changed my AC and Radio display color
