need help....diy fog light
Just a data pt:
In college, I worked UPS at night. I warned one of my coworkers who I saw driving with only his fogs on a J car that I thought that was silly, espec as it risked a ticket or worse if headlights were req'd. Later, the dude ran into something on way to work with, again, just his fogs on.....and messed up both himself and car. Now....I'm dating myself, but I did have aftermarktet Hella fogs that I could enable alone and used perhaps -once- on a TSD road rallye to try and confuse a following car on a rural road (ie no tailights).
Plug back in the connector. Leg one on the relay is where you are going to hook up the wire that you ran from the tapped green/white wire. Leg two on the relay needs to go to a 12v source, and leg 3 and 4 goes back to it's original spot where you took the foglight relay out.
