2000 gs 300 A/C has warm air blowing
Problem: Cool air blowing from Driver side, warmer air blowing from passenger side.
Completed: Coolant is topped off and has not been low. I pulled the dash to look at the servo's. All 4 servo's appear to work. Recirc moves correctly. The Mode servo moves and directs air to the correct vents. I loosened the passenger and driver side blend servo's enough to allow me to manipulate the levers myself. They are both working fine. If I raise the temperature control, the servo will move all the way up and blow hot air. When the temp is lowered the servo will push the gear lower. Any ideas on what else I could check. I pulled the climate control thermometer (not sure what it is called) under the steering wheel hoping maybe it was dirty, but it looked clean. Cabin filter has been changed also. Any ideas on what to do next.
Thanks
when mine did that i think i had air in my coolant line. does your car run a little hot? if so take your cap off the radiator while the car is running and wait to see if you have bubble coming up, and you want to ac on max while doing so. i hope that helps if you haven't already fixed it.
ICGS3
11-04-21 03:14 PM
Blueshark
ES - 5th Gen (2007-2012)
03-20-16 03:14 PM
lilscrapy8
07-02-14 02:20 PM
