lowered my car another inch..... (cont)
Old 09-30-13, 07:48 AM
JamesG
JamesG's Avatar
Default lowered my car another inch..... (cont)
and this is what I get on 3 month old tires............
Old 09-30-13, 07:58 AM
AKS14
AKS14's Avatar
That is why you align your car if you adjust ride height.
Old 09-30-13, 08:29 AM
JamesG
JamesG's Avatar
Did that, done that
Old 09-30-13, 08:41 AM
AKS14
AKS14's Avatar
Well if thats the case either they did a very bad job, or perhaps your tire pressure was way off.
My tires have worn pretty evenly and have a ton of meat, and I have had them on the car with it being lowered for around 10k miles now.
Old 09-30-13, 08:46 AM
01LEXPL
01LEXPL's Avatar
Why does the tread look so low on the good side? Do you drive 100miles a day to bring tread down so fast?
Old 09-30-13, 09:05 AM
sLOWaristo
sLOWaristo's Avatar
mad burnouts is my guess
Old 09-30-13, 10:00 AM
Sampak
Sampak's Avatar
Holy shatballs, that's just weird assuming they're new-ish tires.... Even my other buddy's cambered tires don't wear out that bad and so quickly! There's definitely a tire quality or alignment issue that needs to be traced back. Or the OP is withholding some information (burn outs? LOL I don't think our cars can really do that without some help).
Old 09-30-13, 10:26 AM
LuxuryGS3
LuxuryGS3's Avatar
My used tires last longer than that and I'm -3 in the rear as far as camber goes.
Old 09-30-13, 10:48 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
looks like you were a few treads from a blow out. seriously that is pretty bad.
Sent from my iPhone using IB AutoGroup
Old 09-30-13, 01:14 PM
JamesG
JamesG's Avatar
That was a blowout, its flat...... the only reason I found out (as I never expected them to be bald) was the next morning I went out and looked.... It popped like 3 houses away from my house sat night......
Just got 2 new ones, and as you can see the tread is good on the outside.
Old 09-30-13, 04:15 PM
Bhubb18
Bhubb18's Avatar
Looks like you've got some toe issues
Old 09-30-13, 04:17 PM
sc3O0
sc3O0's Avatar
Wow lol, are you sure you don't burn out?
Old 09-30-13, 05:43 PM
bashigs300
bashigs300's Avatar
I got 5 degree camber on the back and my tires are still new.
Old 10-01-13, 03:49 PM
JamesG
JamesG's Avatar
Turns out camber was in spec, toe was -2........
Old 10-01-13, 11:39 PM
Riksgs808
Riksgs808's Avatar
If youre not burning out and you got an alignment, i honestly think it is tire quality. I hooked my brother up with some new tires from a shop that I worked at. And in less than 3 months he had 2 flats from camber wear. He wanted cheap tires, so he got cheap tires. Tire pressure was good and so was alignment.
Quick Reply: lowered my car another inch..... (cont)
