P0753 code Shift solenoid "a"
I have a 98 gs300 that is tripping a p0753 code. The code reads that is is a problem with the shift solenoid "a". How can I tell which solenoid is "a" after I get the transmission pan off? Furthermore, is there a place to purchase a solenoid or a kit to replace all of them so i don't have to pay lexus prices? Thanks in advance for any help!
Are you sure that's the number code? P0751 - Shift Solenoid A (Valve S1).
I was looking at an IS300 manual. It uses the same tranny. Maybe it's specific to the GS. I thought all GS's got the A650E tranny in '98.
A = Shift Solenoid #1.
It's the one close to the front edge on the side of the valve body that has 5 solenoids on it. Manual shows a testing procedure. It might not be bad. A blockage can set the code too. It's on the opposite corner of the manual valve. I'd suggest double-checking my comments too.
As for parts, I'd check it first and see if it's really bad. Looks like any A650 tranny could supply the parts. You can buy a used tranny of ebay for less than one of these valves costs.
http://www.ebay.com/itm/LEXUS-IS300-AUTOMATIC-TRANSMISSION-134K-MILES-3-0L-2JZGE-35010-53040-FACTORY-12-/300867561976?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AIS300&hash=item460d1aa9f8#shpCntId
Though, this one won't work on the GS. The internal parts would though.
try this thread:
solenoid 0763 fixed
It refers to a different solenoid ("C") but should have all the info you need to sort your car.
Don't forget to update us when you do it - with pictures! - to help others who follow.
solenoid 0763 fixed
missvorn
02-26-15 06:48 AM
GS4.0
18
02-28-09 07:40 PM
