Took apart console to fix SHIFTER and now my KEY won't come out of ignition!
I don't get how dirty fluid is supposed to cause this. The shifter pulls a lever on the transmission which simply moves a slide into different positions on the valve body. There's no mechanical connection between the gears and the linkage or the shifter. There is a gear position switch on the side of the transmission but, if he didn't mess with it, I don't see how that could cause this.
If It worked before he messed with it. That right there tells you he probably messed it up.
user 528962307
Performance
11-29-13 12:15 PM
