Headgasket DIY?
Old 10-21-13, 12:04 PM
99gs713
99gs713's Avatar
Red face Headgasket DIY?
hello does anyone know of a diy for a head gasket replacement or what needs to come off to get to the head, I need some info on this asap thanks for the read fellas
Old 10-29-13, 06:20 PM
Mr Jokster
Mr Jokster's Avatar
Start on page 532 (EM-29) yo
http://www.scribd.com/doc/41771244/Lexus-GS300-Manual
Old 10-29-13, 07:37 PM
MasterKwan
MasterKwan's Avatar
It's a huge complicated job. Not something you want to do if you're a noob. Not without an experienced person standing buy. It's a job that requires a torque wrench and precision. Do it wrong and you'll end up needing a new cylinder head. Should do the timing belt and water pump while you're at it.
You may be very experienced but, asking for a DIY suggests otherwise. I'd never do this job without the manual handy.
Old 10-30-13, 07:42 PM
gsean400
gsean400's Avatar
Buy a used engine. There are places that import the engines from japan and you can get em for the price of a expensive torque wrench. I was quoted 490 for a used one with 110k and one just core for 350. Thats for a 1uz or 2jz. Of course a gs430 would be a little more expensave
Old 05-30-20, 08:09 PM
naqvi
naqvi's Avatar
I had same problem. Started with first engine needed head Gasket. I purchased a used engine and changed it. Only had 120K on used engine. A month later it needed a headgasket. I am changing it now. have head almost out, stuck on intake manifold. seems like must remove it before head is taken out. Looks like wiring harness goes through it. Looks like a royal pain to remove intake manifold. Any input be appreciated.
Old 05-30-20, 10:07 PM
silverbul
silverbul's Avatar
Subscribe to this site & it gives you everything about the lexus GS. I think I paid $24 for it
Old 06-01-20, 09:27 AM
FrankT
FrankT's Avatar
Keep it on and unbolt it on the work bench... pull the wire harness out first.
Good luck.
Old 06-23-20, 12:16 PM
naqvi
naqvi's Avatar
2001 GS300
Head is out getting checked. Supposed to get it back today. Searching for parts. re-torquing head bolts will be a pain. Is it ok to use those metal gasket advertised as no re-torqing required. Anyone has used those? I am buying new headbolts and washers. Any advise for reinstallation will be appreciated. Parts Geek has it for $144.00, not sure to use it or not. Thanks.
LEXOVE
CL of Southern California
10-21-14 09:11 PM
MyIS350G
12-03-12 07:14 PM
Percy
08-09-10 06:22 AM
xsohaib
15
05-22-06 10:49 PM
anks106
Performance & Maintenance
04-13-04 05:23 PM
Quick Reply: Headgasket DIY?
