Resonator Delete?
I'm a noob with exhaust but want to be a little more loud. I've looked up the cat back and axle back replacement and I don't really want to spend the money right now just for a little deeper sound. I'm on the verge of cutting out the resonators but I wanted to consult you guys first for any input you all might have. I'm lucky enough to have never had a check engine light come on and I really don't want to set off any codes by doing this. So should I do this? Thanks
iModerate
No codes will be set by this mod. Worst case scenario you may loose some fuel economy and/or performance. I personally doubt it will be noticeable if it does happen and have not read of this happening to anyone that has done it.
Removing the rear 2 mufflers (near the bumper) will result in a deeper rumble when you step on it, but also cause an annoying drone around 1500-1900 RPM under acceleration typical for highway/main roads. If you can live with that, go for it.
On the other hand, removing the 2 or all 3 resonators (there are 2 cylinder shaped side by side, and 1 just in front of them that looks more like a muffler) will give you more noise and more character if you keep the rear 2 mufflers only. Not sure on drone, as I don't have this setup, just the first one above.
However, I believe while the first options might give you a 1-2 HP, and sounds decent, the drone sucks for long drives where you are not at a constant speed (highway or cruising is OK, it's not loud). However I believe that real character of a V8 sound is lacking (the chatter/blurb/rattattatatatatat you hear in other V8s) so I think removing the resonators, and keeping the mufflers (or an after market muffler set) will give you a more aggressive sound profile with some rasp etc.
There are a few videos on youtube of gs400s that show step by step how the car sounds stock, then resonator delete, and muffler delete, then aftermarket mufflers (although it's impossible to tell from a video how yours will sound, it's a good reference of what I'm talking about).
Most likely when removing ("deleting") a resonator, or muffler in my car's case, the missing section is replaced with a simple piece of piping of matching diameter. This is the way the mufflers were removed from my car by the previous owner, while keeping the factory exhaust tips in place so no one would know it is missing mufflers if they just looked at it from a distance.
if u want a deeper sound check out borla mufflers i deleted my resonators and put borla mufflers on mine it gives me a nice deep sound but of course keep in mind i have a 2jz-gte swap so it might not have the same exact sound but there are some vids on youtube of borla mufflers they have kits for sale that are bolt on and come with tips that look like the stock ones
iModerate
Resonators or any part of the exhaust after the catalytic convertor (actually, after the O2 sensors) on most everyday cars never causes any kind of Check Engine Light (CEL/MIL) or error codes because the engine has no way of "knowing" anything has changed, especially if it is a resonator or muffler way at the end. The only way to fail is to have a visual inspection of your exhaust where it's very obviously missing a large chunk of it and is obnoxiously loud like a fart- I mean Harley bike, in which case it may or may not still depending on the tech doing the inspection and what happened between him and his wife the night before.
What CAN commonly cause a check engine light is swapping the intake for a cold/warm/short-ram intake on *some* cars like the GS (no issues on say, my '06 Sentra, or '08-'12 Altima Coupe) and fiddling with the catalytic convertor(s) that are up the line from a waiting O2 sensor.
LOL. To repeat, no.
LOL. To repeat, no.
ya something along the lines of a visual inspection is what i am more worried about. if im not mistaken straight pipe for instance can net you a fix it ticket in ca and now ive moved to tx and i dont know if straight pipe is legal or illegal and removed resonators i have never been sure if you can get fix it tickets for or not.
Resonator / muffler deletes don't seem to matter to anyone as far as I have seen (and god are there enough bad apples here) especially given how trucks run around with modded exhaust, nevermind all the vtaaaak tunerz and Muscleheads .
Straight pipe I'm not sure of. As long as your car is not too bad on noise you could get away if you still keep your cats. There are plenty of those examples here in DFW as well. Though I have no idea if they really passed inspection or if they do the swapperoo before testing.
Remember most brand name exhausts often get rid of or add different resonators and mufflers left and right to get your car to sound a certain way, while most likely under the required 'legal' noise (decibel) limit so they can easily be sold as street legal. Of course, take that with a grain of salt (plenty of somewhat borderline loud exhausts and "off-road pipes" that are not exactly street legal).
thanks sam what part of dfw you live, i actually live in dallas at 30 and buckner across from racetrack. i think ill look into getting rid of the resonator once i get this damn vsc, abs, vsc off light gone. i changed stock muff to borla and changed a cat and now this happens *facepalm*
I deleted my resonators and added some magnaflow mufflers....sounds like a 350z now...i can put up a video on here of the sound. i personally love it... a little rasp, but thats what happens when you take baffles out of an exhaust system.
