Brake light comes on intermittently
I don't have any idea since I haven't had to mess with mine, but I'd check on brake fluid type with the dealer, otherwise I'm sure there's some threads on here that could turn up something in a search.
Ook this is what a little google time turned up:
Toyota Dot 3 Brake fluid. I've also seen other sites recommend 5.1 but I don't know if that's ok or not (of course you don't want to mix anything).
http://lexus.sewellparts.com/accesso...1998/4368.html
Recently my brake light on the cluster keeps coming on. Its intermittent, but from researching it seems to point to low brake fluid. I just had my wheels put on and the shop said the brakes were ok, still plenty of wear left.
That being said, which brake fluid can I use with the existing stuff in there? Ive looked at these, but not sure if there is something better?
ATE 706202 Original TYP 200 DOT 4 Brake Fluid - 1 Liter
Amazon.com: ATE 706202 Original TYP 200 DOT 4 Brake Fluid - 1 Liter: Automotive
Castrol GT LMA Brake Fluid - 32oz. 12504
Amazon.com: Castrol GT LMA Brake Fluid - 32oz. 12504: Automotive
I am not too sure but sounds more like there is a small leak, you should take it to another workshop if you can't seem to find the exact problem or solution to it.
