Jdm Aristo Power Folding Mirrors w/LS600 housing...
The mirrors can be found on Yahoo Auctions Japan... just do a search for JZS and LS600... should come up with a few different options as they're quite readily available [in Japan].
No, the mirrors don't bolt right up. They're covers (similar to the ones Nigel sells)... so to use them, you'd have to find either an earlier or later model version of the mirror depending on what year your GS is. Then, also take them apart, swap out them out, and put them back together along with wiring them to work with your turn signals and I believe these also have a puddle lamp built into them.
Pic posted.
Thx
Ty sir.
Not that I know of. Nor am I a fan.
I got them from Gill who's a 2gs cl member. He got it thru his connect in Japan.
No link but if you or whoever is interested I can contact him directly to order.
Me too thx!
Sure are. I love that they're black to go with my recent black interior conversion.
Yea that woulda saved me some $$!
Should be top secret lol jk. PM me if you'd like to order. That is if he can still get them which I assume he should.
Nope not that I know of. Just PM me for ordering.
Hi J$mooth23,
I'm new in this site and am ordering as it is my first day here. How you match or make work the JDM Mirrors Wires with the USA Original Mirrors Wires? I just bought those and I found them in the same color of my car, but I can not do work because the JDM mirrors are just 7 wires and mine has 11 wires? Can you help me with this please. Thank you very much in advance. Mcon0101@yahoo.com
Mike
Mike
Hi J$mooth23,
Mike
Mike
Hi J$mooth23,
Mike
Mike
https://www.clublexus.com/forums/gs-...install-4.html
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Hi
Could you tell me where I could connect all 7 JDM wires to the 12 USA wires that my 2GS brings?
I'm stock for several days because I could not configure these wires power folding mirrors. I trying to set up as wiring the cables but I can't.
I have a GS300 04 and the JDM power Folding Mirrors are from 1998 Aristo. I need help please.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Thanks in advance for the help you can give me.
Hi Guys,
I installing the JDM Power folding mirrors motors on my original USDA frame mirrors. WHATTTTTTTTTTT???? Yesssssssss, I installing the folding motor in my original mirrors frame and did not lose any of the futures of my mirrors. As the heated mirrors, memory, movement, diam. I start remove the mirrors of each frame (JDM and USAD) mirrors. After take the mirrors out, I take the base out of each one, get the base that use a spring of my original mirror 9USAD), then remove the motor from the Japanese mirror and transfer it to the USAD Mirror Frame. EVERYTHING FITS INTO THE PLACE OR POSITION WITHOUT ANY PROBLEM. What I do not like the whole process was having to cut the wires of each mirror to TRANSFER the MOTOR to the original USAD mirror FRAME. The reason for this is, that all the wires pass through the center of THE MOTOR and THE BASE SPING of the original mirror and you need to transfer THE MOTOR FOLDING MIRROR to the original Mirror FRAME.
NOTE: Cut all the wires close as you can to the MALE PLUG and then connect them back of the easiest way for you. I connect back all the wires of my mirror with my BUTT CONNECTORS and it became easier that way for me. I tell you this guys because that way you won’t have problems installing the interior door panel back to the door with the wires on the way of the panel door. That way all the mirrors cables do not interfere when you installing the door panel back. But YESSSSSSSSSSS, you can transfer the FOLDING MOTOR to the ORIGINAL FRAME USAD MIRRORS. I not has time to install the ORIGINAL switch get, but I can make work with the mirrors. :-)
I use the DPDT Switch to open or close the mirrors. You can buy on eBay. So, runs and buy this JDM Power Folding Mirrors on eBay and enjoy your folding mirrors as well as I'm doing. :-)
Hi Guys,
here is a pic showing how both the JDM and the USDM mirrors are different.
You can however switch the JDM mirror mechanism and frame into a USDM housing if you wish but it would be pointless. As final mirror position relative to drivers and passengers side lies within the mirror.
I’m currently working on my set of JDM mirrors and am going to check if I can switch mirror bases between driver and passenger.
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/0069bfff_3173_4425_9432_8cca592ebf9d_0291fd6d34ccef1821129e6d57798b00603f0a34.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/fe3653eb_e612_4eb7_a0ce_606ba65ccfac_8329690e45ce0932682a1529a57bda8c25899178.jpeg)
