Dome Light/Key hole light/Foot well lights out
sounds like you burnt out the door ecu..... i did this when i did the LED turn signal DIY i made. if you have a local member near you see if they will let you borrow theirs and check it to see if thats it. a friend of mine ended up resoldering the connection for me and fixed mine but im fairly certain this is what you did BUT where you really doing something else cause installing a LED shouldnt cause this to spark, if you put it in backwards it wont have the correct polarity to come on and if you put it in correctly there is no reason it should spark unless you have a short in the wiring (maybe look back and see if any of the wiring is exposed)
BTW im 99% sure i posted the wiring diagrams for all this in that DIY
so you checked both sides of the fuse boxes located in the front kick panels (driver and passenger) as well as under the hood? normally when that "spark" happens, you pretty much popped a fuse. although you said you checked EVERY single fuse and everything is normal, i don't see how it sparked unless the previous owner "ghetto rigged" some wires to make a radio work and wires are exposed somewhere that caused a short. or maybe it's the bulb that blew... did you replace it with another bulb to see if that bulb turns on?
No, no I hear you loud and clear. When checking the ecu, What exactly should I look for? Sorry if I made you mad. I'm still learning this car.
I'm in the exact same boat...
Installed LEDs in footwell
No foot light / No ignition light / No dome light (spot light works though)
No sparks noticed.
Checked every fuse (but haven't checked relays...)
As much as we all loooooooooove to ignore sakataj , I never thought about looking into the door ECU.
From that tiny wire diagram (thought helpful, since manuals from the sticky are no longer available...), the door ECU looks like a common point where all 4 lights (right + left foot light, dome, and ignition) are wired...but I can't make out the letters and symbols... Can someone post a bigger version of this diagram?
Hopefully it'll be an easy fix as re-soldering...
No sparks noticed.
mine was that simple, open the door ecu and look over it
the body ecu is in the C panel right? if so then thats DEF not the ecu i fried
So I am still diagnosing. It is Definately a ground issue.
Here what I have done so far
I went to get a test light and aligator clips. I connected the aligator clip to a known ground source (a bolt on the door hinge) and the other end to the spliced green wire. Attached to the driver side foot light. As so as I connected the clip, everything lit up like a Christmas Tree. I will take out the door ecu tomorrow and try and locate a grouse issue. Here are some pics of the way that I have it connected for the test
So I took the drivers door panel off and got the drivers Door Ecu out. I snapped a couple of pics. I scanned the circuit board for any burned or abnormal spots and I did not notice any. I also check connections at IJ2 which is to the left of the blower motor, behind the glove box, and still no ground. I think it is time to try and get to the body ecu NO.2 now.
89222-30020 is the part number for the Driver door ecu BTW for future reference.
Yea it does suck. I found a wiring diagram and started to diagnose my ground problem. I have not been able to test the Body Ecu No.2 Green #13 ground wire yet, because I can not figure out, how to remove that ecu. I think that it is the body ecu itself. I'm thinking about, just wiring up the light circuit to a separate switch and just turn the foot lights on while I drive at night. At least for a temporary fix.
I do not, I made a thread in the North Texas section, but haven't had any responses.
SMOKEYVIP
04-12-10 01:32 AM
Jellopool
05-18-08 03:35 PM
