Starter issue, bite the bullet?
Old 11-26-13, 01:58 PM
Arcadian
Arcadian's Avatar
Default Starter issue, bite the bullet?
2000 GS400. A couple weeks ago I got the issue where I turn the key and just get a "click," no starter engagement. I had the same thing about 3-yrs ago and replaced the starter with OEM. I took the car into my dealer and they've had it 5-days now and it starts fine for them every time.
Should I just bite the bullet and tell them to put a starter in? I just know if I take the car home, it will quit at the worst time (probabaly when it's -30 freaking below!)
Thoughts?
Old 11-26-13, 02:38 PM
ThomasGS4
ThomasGS4's Avatar
Honestly, I'd check to make sure the battery terminals are in tip-top shape, then wait until the problem is persistent enough.
Old 11-26-13, 06:44 PM
GTE4Life
GTE4Life's Avatar
About 4 years ago my SC300 had a problem staring where i would have to turn the key about 10 times for it do engage (otherwise it would just click like you describe). I spent a few hours and removed the starter and cleaned ALL of the contacts with a dremel wire wheel, cleaned the starter terminals, the wires that connect to the starter, and both battery cable ends and battery posts, it starts great with one turn of the key still 4 years later and that is all i did, i believe it is the original starter too this is a trick i try on all of my cars now just to see if it works...it doesnt cost anything except time.
On the other hand if you ar uncomfortable working on your own car you may just want to have one put it, i bet the dealer will charge an arm and a leg though.
Old 11-26-13, 08:08 PM
toy4life86
toy4life86's Avatar
I second the battery terminals the starter is a hard task
Old 12-18-13, 05:55 AM
yelnoc
yelnoc's Avatar
Default Similar/same problem here
My issue is similar - '03 GS 430 - very intermittent. When all is good it starts fine, but once in every 2nd or 3rd drive, it will click once and then start, rarely it will click twice and then start. When it starts everything seems strong/normal. Will try the battery terminals.
Old 12-18-13, 06:27 AM
sakataj
sakataj's Avatar
do it yourself....
https://www.clublexus.com/forums/gs-...-problems.html
Old 12-19-13, 12:11 PM
lexusben
lexusben's Avatar
A few years ago when it got cold out my car would not start the first time that I turned the key. I just got a clicking sound. Then last winter things got progressively worse to the point that I would have to turn my key 20-30 times on some occasions before my car would turn over. I replaced my starter last year and I haven't had the problem since. My car is a 1998 Lexus GS 400 with 178,000 miles on it. It probably had around 170,000 when I replaced the starter. I think the cost was around $220 for the starter from Sewell and $400 for the install at a shop nearby. If you go the dealer a starter replacement will easily run you over a grand, though.
On the other hand, it could definitely be the battery terminals. However, when my battery terminal were corroded my symptoms were a bit different. My car actually died while it was running and then refused to start when my terminals were corroded.
Old 12-19-13, 02:40 PM
Lukas99GS
Lukas99GS's Avatar
Is this any easier to change on a 300? Jw
Old 12-19-13, 10:47 PM
FrankT
FrankT's Avatar
Bite the bullet and DIY...
If you have just a bit of skill turning wrenches you can do this.
A few years ago when my starter went I spent $27.00 for new contacts and plunger, along with three hours of my time.
Read the link posted in post #6
GSmamba
05-01-18 05:48 PM
Marlow
06-25-11 06:33 PM
jcastaneda
02-02-11 09:46 AM
b1gredek
10-07-04 08:45 AM
airahcaz
Performance
04-25-03 01:19 PM
Quick Reply: Starter issue, bite the bullet?
