Remote start?
Remote start?
Has anyone had remote start installed on their GS? Thoughts? Sometimes I wonder if doing one of these aftermarket remote start systems would mess up the electronics of the vehicle? Any thoughts are greatly appreciated. Thanks!
how far is the range? and is there a booster?
Hmm, this sounds like too much trouble for what it is worth. Thanks everyone for their input, however I think I will pass. Will just have find one someday with a factory option.
I have the Clifford 590.2x and it has been in my car for just over 2 years now without any problems. The range on this system is great. I am using a Directed 555XW in conjunction with the alarm to send the signal to the ignition. It learns when you start the car with the key and reproduces the signal without having a second key in the car near the ignition (hopefully I explained that right). Total I spent was about $400.
So what exactly does it take to install for example that Viper 5704 or 5901?
What do I have to take into account when installing it?
Is it just plug-n-play or does it need a car electric professional to install it?
You gonna need these Directed 556UW Universal Remote Start Interface Module to bypass the ignition chip . you gonna wired to the door lock either the driver or passenger door. these wires can be found in the kick panel so no need to go into the door . gray pnk/blk pnk/grn.
For the ignition 12 volts white / blue
second 12 volts white/red ,
starter black
ignition- white /black
second ignition blk/yellow
