What Is This!?? Resonator or Cat?
Old 12-16-13, 08:59 PM
mrrhr4
mrrhr4's Avatar
Default What Is This!?? Resonator or Cat?
Can someone tell me what this is lol. Its on a 2001 GS300! I want to delete it but curious to what it is thanks!
Old 12-16-13, 09:14 PM
gsean400
gsean400's Avatar
Idk.. Mines A cat But mines a 430. I was going to delete it also, but i didnt know if i would still pass emissions or if it had a 02 sensor.
Old 12-16-13, 09:43 PM
mrrhr4
mrrhr4's Avatar
Oh okay.. but yea man i dont want to throw a code or bs like that lol
Old 12-16-13, 10:27 PM
NorthStyle
NorthStyle's Avatar
I doubt you'd throw a code as all of the oxygen sensors are upstream of it (if it's anything similar to the GS400/430).
Old 12-16-13, 11:04 PM
Lutkis
Lutkis's Avatar
Isn't there a pre and post cat sensors? Wouldn't it then affect somehow if you remove the cat?
Old 12-17-13, 03:01 AM
SprtDesign
SprtDesign's Avatar
its the 3rd cat. It should have a o2 sensor behind it. Install deleted pipe an place an o2 simulator w/ o2 sensor in the bung.
Old 12-17-13, 09:39 AM
ThomasGS4
ThomasGS4's Avatar
The third cat doesn't have an O2 sensor behind it. In theory, you should be able to remove it and be perfectly OK.
Old 12-17-13, 10:47 AM
gsean400
gsean400's Avatar
Am i the only one willing to delete this? I feel like im going to be the only 1 with a 430 to delete the thrid cat. I didnt delete it cause i dont know anyone on this forum that did.
Old 12-17-13, 11:00 AM
ThomasGS4
ThomasGS4's Avatar
I actually have a 2001 GS430 catback on my car, as I swapped with a fellow who wanted the complete resonator/center muffler/cat delete I had on my car. So yes, it will be just fine.
Old 12-17-13, 12:57 PM
aneidiaz
aneidiaz's Avatar
I have an 01' GS430. Since mine has 2 catalytics up front and 1 going back, I'd agree to say this is a catalytic converter. My mechanic says most ppl do not know this until further researching it. He says there's no sensor hooked up to it so there's never an exact way of knowing weather it's bad or not. Once it's TERRIBLY bad, you'll NOTICE. I hope whatever your problem is, it gets resolved soon. Good luck my friend!
Old 12-17-13, 01:01 PM
aneidiaz
aneidiaz's Avatar
Hey Thomas, when you swapped out your 3rd catalytic, did you ever have any CE light problems with it? I just purchased my cats new from Sewell and I am doing a full exhaust tune up soon. I noticed that all o2s are located BEFORE this 3rd cat.. I see you wrote it's ok. So is it really? I'd like to do that to my GS430 bro. And if it did work out all properly, did it give you any type of change performace wise? If you can share your personal take on this, I'd deeply appreciate it bro! Any pics of new catback swap? Yes Yes!!
Old 12-17-13, 02:21 PM
mrrhr4
mrrhr4's Avatar
Meee broo! Lol so its a cat? No O2 sensor behind it... sounds pretty removable to me
Old 12-17-13, 02:43 PM
LALEX1
LALEX1's Avatar
Default gs430
When I had my gs430 supercharged i killed my 2 front cats, so I removed all three cats and had larger piping and 2 hi flow aftermarket cats added up front. Deleted the rear. Much cheaper than buying oem cats, no cel light car ran great. I have since removed the SC and car still runs perfect. Been a couple years now.
Also cats are california compliant and passed smog just fine
Old 12-17-13, 11:49 PM
gsean400
gsean400's Avatar
Now im mad i didnt delete the third cat. Going 3 inch piping soon. Prolly will delete it then
Old 12-18-13, 02:17 AM
NorthStyle
NorthStyle's Avatar
Are you going forced induction? If not, then you don't need 3" piping unless you just want a loud car. ****-adkt schooled me well on that.
Quick Reply: What Is This!?? Resonator or Cat?
