Fuel Leveler Issues
Fuel Leveler Issues
I put a used fuel pump assembly in my 99 gs300 I think now my fuel gauge is off but sometimes I think it is right but one time it showed I had 1/4th tank then it almost died and I had no fuel what can cause this or what should I look for before the fuel pump went out the gauge worked good.
thanks for the reply that may be it my dad installed the pump I will be looking into this right now it says I have a quarter tank but I doubt it I am not getting stuck so I am going to put gas in it after work, the floater is not floating and being accurate so I assume it may not be in the right position like you said.
which is the correct way so I know how to put it or I have to look at the levelr so I know it can go all the way up and down any other info would be helpful for now I will put gas in it everyday to be safe or half tank
i had the same issue about having a 1/4 showing and running out of gas. i think my car is not getting fuel from the passenger side over to the driver side tank correctly. i think there is something wrong with the jet pump that pulls the gas over from one tank to the next.
hey yea my dad said he is sure he put it right so I have to take the cluster out or just the face of the cluster yea I think about 1/4th its really low when it should show the light and be on e or below thanks for the info fellas
Hold it down for at least 10 seconds and keep it held in while you hit the reset button....reverse the order and try it the other way, I gotta 98 gs400 and it works for me.....hmmm did u try resetting the ecu, take the negative terminal off your battery for a half an hour, I would try that next if my suggestion don't work.....
I tried this it did nothing what would be the next step my dad says he is 100 percent he did it correct could it be the leveler was not working on the used junkyard assembly I bought It was sitting on a shelf for awhile I assume, but the gauge worked when I put fuel in it, I have not put a full tank in it yet should I try this.
It's not just the position,
you got to make sure all the tubes/hoses and the jet return inside the tank are all are pointed in a way so they aren't interfering with the float. A few of those guys swivel around
LoveSCs
Performance & Maintenance
11-04-21 11:41 PM
