Valve Cover gasket replaced NOW bigger oil leak
So I had to replace the valve cover gaskets on the 03 2JZ. there was no doubt they were leaking as I would have a drop of oil appear every morning and it showed on the plug wires in the valley. Now a week later I have 3-4 drops of oil underneath in the morning! I valley is dry, everywhere I can see/feel around the valve cover is dry. It appears that its coming from the timing belt cover. What would cause this to leak this much all of the sudden? Could it be that it appears to be from the cover but is really coming from somewhere else? From underneath there is no doubt its coming from the front of the motor.
Defiantly not the crank, could be the cam seal. If so would that just be a bad timing sort of thing? Meaning, I didnt mess with anything around the cam seals to cause them to start leaking.
Where is the easiest place to glance at to see if its the cam seal? I have looked around the timing belt and do not see any signs of oil.
Thanks!!
Thanks!!
Just curious how long it took you to change the VCGS as I'm planning on doing that and plugs for the first time on this car, did you make sure to use RTV and torque the covers back down to the correct tightness?
Torqued and RTV yes. this oils seems to be coming from somewhere OTHER than the repair I did. Either is a coincidence or I bumped/moved something i should have.
Sitting at 125K, did the valve cover, plugs, wires, coils If you are in that far you might as well do it all. My bigest problem was all the brittle as shizz connectors!, several of the retaining/holding clips cracked.
Bro of the valve cover gaskets have been replaced, inspected afterwards, and confirmed they are good, can only be the head gasket or the oil pan gasket... I doubt it's the head gasket bro.... check your oil pan.. if in doubt it's that, take your time when you do it. Clean the components up nicely, get new bolts if the old ones are really worn, and do a good job. Everything will be alright. I hope your issue is solved soon! Positivity!
Do not be fooled by oil leaks on these cars. Just because it is at the bottom does NOT mean that the source isn't at the top. Oil trickles down and can fool you if you don't inspect carefully. My cam seal leak had majority of the oil by the oil pan. Wasn't until I pulled the cover when I noticed where it was actually coming from.
