Help, please -- messed up timing belt job
Old 12-27-13, 08:35 AM
ThomasGS4
ThomasGS4's Avatar
Originally Posted by krisch
Your motor is non interference therefore will never bend valves.
just put the gear back on and re time it and youll be ok.
This is not true. The VVT-i 2jz is interference, where as the non VVT-i 2jz isn't.
Old 12-27-13, 08:37 AM
LEX_GS4
LEX_GS4's Avatar
nope, all Toyota timing belt motors are non interference other than the 1uz and the 3uz v8 motors.
Old 12-27-13, 08:46 AM
ThomasGS4
ThomasGS4's Avatar
You're absolutely entitled to your own opinion, but facts are facts; the 2JZ-GE VVT-i, which is what the OP has, is certainly an interference engine.
Old 12-27-13, 09:03 AM
porn-adkt
porn-adkt's Avatar
2JZ VVTI = Interference
Old 12-27-13, 09:45 AM
repugnante
repugnante's Avatar
Things can always be corrected as long as you don't start the car.
2JZVVTI is an interference motor. Along with all Toyota V8's...
Old 12-27-13, 09:50 AM
porn-adkt
porn-adkt's Avatar
Ive had the Luck to experience two water-pump failures on two GS4s... One destroyed my engine.. the Other did nothing...PURE LUCK...
That Timing belt and Water pump can be time bombs if your not careful with your maintenance..
Old 12-27-13, 09:53 AM
repugnante
repugnante's Avatar
On my last timing belt replacement, one sprocket moved a notch when I put the belt back on. I didn't notice it, but a buddy of mines did. Thank God! I would've double checked anyway, but still.....
Old 12-27-13, 09:56 AM
repugnante
repugnante's Avatar
Sure can. That water pump is the catalyst of the timing belt. Must be maintained
Old 12-27-13, 10:00 AM
porn-adkt
porn-adkt's Avatar
"That one notch" i hate that..
Old 12-27-13, 10:08 AM
LEX_GS4
LEX_GS4's Avatar
oops, ok my bad i found it.
Old 12-27-13, 12:27 PM
VIP161
VIP161's Avatar
This is interesting. I used to have a 01' GS430 that had a timing belt break on me. 9 valves were bent. I found that out when I had put everything back together with a new belt. I had called around a few Lexus Service centers and talked to a handful of Lexus/Toyota experts because I was getting mixed information, and they all told me the same thing. Only the UZ engines are interference engines and not the 2JZ.
Old 12-27-13, 01:37 PM
repugnante
repugnante's Avatar
^ You are the first person that I know of who had that belt snap on them. These belts are damn near teflon. How many miles did you have when it snapped???
Old 12-27-13, 03:04 PM
Ava92
Ava92's Avatar
4AGE is interference. Don't spread misinfo if you don't know what you're talking about
Old 12-27-13, 03:09 PM
porn-adkt
porn-adkt's Avatar
Old 12-27-13, 03:35 PM
ttaylor993
ttaylor993's Avatar
Just thought I would throw my 2 cent's worth into the interference/non-interference discussion. Here is a link that list all motors.
http://www.agcoauto.com/content/List...erence_Engines
Quick Reply: Help, please -- messed up timing belt job
