no cabin air filter
Old 01-08-14, 04:52 PM
gstreee
gstreee's Avatar
Question no cabin air filter
Its cold as hell up here in NYC and my 2gs is not giving heat....it blows air but only cold air. the temp could be all the way up to 85 but no warm air.....I decided to check my cabin air filter, don't know whether it has anything to do with my problem or not but i figured its probably hella clogged and dirty. open the glove box, remove the panel and wow i have no cabin air filter whatsoever......not even the cartridge that holds the filter...i could buy a filter but what about the cartridge???
Old 01-08-14, 04:58 PM
Dueces
Dueces's Avatar
I don't think not having a filter would hault your heating capabilities but i would reccomend getting one so that nothing blows in your face when the a/c is on. Sounds more like a malfunctioning heating unit.
Old 01-08-14, 05:15 PM
ttaylor993
ttaylor993's Avatar
I agree, it sounds like the heater. You can probably find a filter cartridge very cheaply at a salvage yard.
Old 01-08-14, 07:17 PM
aneidiaz
aneidiaz's Avatar
Bro your having a SERVO problem......
Old 01-08-14, 07:24 PM
aneidiaz
aneidiaz's Avatar
https://www.clublexus.com/forums/gs-...vo-motors.html
There's the link on how to change out your servos bro. Read it VERY carefully.... By the sound of the description, it seems like your temperature servo which is referred to as the "COOLING SERVO' in that link is what's wrong in your car. It's what changes the actual temperatures of the air coming out your vents from cold to hot. The MODE SERVO changes the functions of where your air is coming from. Head to feet to head+feet, for example. I hope this helps out.... Look things over and carefully understand what your looking at and what your doing. It's a simple fix. I did it myself.
Old 01-09-14, 09:39 PM
gstreee
gstreee's Avatar
thanks brah
Old 01-09-14, 09:59 PM
aneidiaz
aneidiaz's Avatar
Originally Posted by gstreee
thanks brah
No prob bro. Read read read!! That's all I can say. It shouldn't be too hard. I'm pretty sure it's your servos that's gone wrong.
Old 01-10-14, 06:53 AM
repugnante
repugnante's Avatar
If that doesn't fix your problem, it maybe your heater core. Check your coolant levels and make sure the system is full of coolant. The heater core needs coolant for you to actually feel the heat.
Old 01-10-14, 07:31 AM
mexikan
mexikan's Avatar
Is your temp gauge the normal range (somewhere in the middle) With weather this bad you should put a piece of cardboard in front of your radiator.. I've done this had no problems but don't block it completely.. If the gauge shows normal then your problem is else where..
Old 01-10-14, 01:19 PM
porn-adkt
porn-adkt's Avatar
Originally Posted by mexikan
is your temp gauge the normal range (somewhere in the middle) with weather this bad you should put a piece of cardboard in front of your radiator.. I've done this had no problems but don't block it completely.. If the gauge shows normal then your problem is else where..
wtf???.......
Old 01-10-14, 08:10 PM
CAKETOWN
CAKETOWN's Avatar
Originally Posted by ****-adkt
wtf???.......
Pretty common thing to do here in canada. If its -40 C just think about how cold the air is when your going 100km/hr. Blocking the rad properly helps the car stay at operating temp.
Old 01-10-14, 08:24 PM
porn-adkt
porn-adkt's Avatar
U serious man? at minus 40 deg F or C you should not be out driving, these are dangerous temps..Not only will your rad need cardborad but alot more stuff, all types of things can happen..
You make it seem likes its a common thing... No need for carboard in NY
Old 01-11-14, 10:40 AM
aneidiaz
aneidiaz's Avatar
Dam -40° is harsh..... I'd relocate man. I thought PA was cold. You guys are brave out there man. Props abd much respect! I hope everyone out there drives safely and stays warm at all times. Amen.
Old 01-11-14, 02:44 PM
CAKETOWN
CAKETOWN's Avatar
yea im dead serious.. if you think driving in that weather is dangerous? Try working in -53 C for 11 hours. I wonder everyday why i live out here... free health care and higher wages i suppose.
Old 01-11-14, 05:46 PM
aneidiaz
aneidiaz's Avatar
Dam bro you should relocate. That sounds pretty tough. Like Alaskan life. That ain't no joke. We only talk about those temperatures down here in PA when we talk about working in meat freezers. That's cold bro. I hope all is well.
Quick Reply: no cabin air filter
