Aristo Swapped 99 GS300 ...questions
Old 03-11-14, 12:10 PM
empera
empera's Avatar
Default Aristo Swapped 99 GS300 ...questions
I have a 99 gs300 with a non-vvti stock Aristo swap that i bought a couple of weeks ago and i have some questions.
First the A/C doesn't work and would like to know if there are any threads covering how to get this working?
Also my stock water temp gauge isn't working....any ideas?
Also my gas light supposedly is flashing so the previous owner removed...not that big of a deal but would like to get it that to work as well.
Thanks for any help in advance!
Old 03-13-14, 07:16 PM
empera
empera's Avatar
Could anyone point me in the right direction as to where i can find the wire that goes to the temp gauge from the body plugs in the ecu compartment?
This is what im looking at now....
Would be nice to know what the colour of the wire is or what pin it is....
Old 03-14-14, 07:29 AM
empera
empera's Avatar
Anyone? ......
Old 04-10-14, 09:35 AM
empera
empera's Avatar
is there anyone that can point me in the right direction?
Old 04-10-14, 10:35 AM
flexspeed
flexspeed's Avatar
there a few people in here that done that swap, but depend on the power goal, you should of got the VVTI Gte and it would be less headache ..... but since you got this far... compare wire of the non vvti and vvti.... using a wire diagram... its going to take some time... and stress....... find out if your gte is from a supra or aristo... sometime color ... it can be different too... so... with some research... you will figure it out... but it be nice if someone here will pin point you.... good luck
Old 07-23-14, 08:24 AM
empera
empera's Avatar
Is it possible to wire up the AC Compressor on a manual switch with a relay perhaps? That way i can have it come up when the climate control is on and "cold" ?
Old 07-23-14, 03:09 PM
MrHimbert
MrHimbert's Avatar
On the contrary i believe that VVTI is more of a headache than anything. Ever Heard of the acronym K.I.S.S?
As far as identification color is not always an identifier. Is the engine oil pan a rear sump, or a front sump?
Aussiegs3
12-20-17 12:05 PM
876
Performance
10-24-16 07:23 AM
For0nlyu
10-11-15 09:56 AM
PMP 300
07-06-11 06:04 PM
MRMOCOS
GS - 1st Gen (1993-1997)
11-06-08 11:29 PM
Quick Reply: Aristo Swapped 99 GS300 ...questions
