gs wont start... new motor
Old 03-13-14, 12:49 PM
whit3b0y
whit3b0y's Avatar
Default gs wont start... new motor
Need help. My 00 gs dying at 220k. Tranny ( 3f302 ) lost 1st and 3rd. Motor has bad 02s, bad valve cover gasket,b ad head gasket.
Bought a 04 2jzge, and a 3f500 tranny, all new o2s, obx header. On the motor swapped wire harnes, serpentine pulley and timing cover. (Cover had been smashed in old vehicle). Tried to pull crank pulley with nuematic gun and could not break it loose. So use a compressor and blew out the timing cover to assure nothing had fallen in during previous accident/shipping. Installned in car, no star. Cranks but firing. Then checked the firing order, but with the coil packs you cant mix them up. Changed fuel rail and injectors. Since the wiring by the plugs was brittle as we all know, cut off the 04 wiring for the coil packs and soldered that in place of the old. Same...plugged in my obd scanner and it shows a po1300. Changed to the origanal 00 coil packs. same.... a buddies friend came over and checked it and said ecu was wrong/faulty.... said it needs the 04 ecu...
if everything is origanal but the block how is the ecu wrong? How often do these fault? Fault unplugged just sitting?
Old 03-13-14, 09:04 PM
clos430
clos430's Avatar
Are the keys programmed to the ecu ? Meaning the immobilizer ?
Old 03-14-14, 12:23 PM
whit3b0y
whit3b0y's Avatar
Original key and original ecu
Old 03-14-14, 03:47 PM
egs21
egs21's Avatar
I will sell you my mint condition 2002 GS300. Just cracked 90k this past week. Had the 90k service done already. Car needs nothing.
Old 03-15-14, 03:25 AM
whit3b0y
whit3b0y's Avatar
Is it pearl white with black interior?
EndlessRed
CL of Southern California
11-27-18 10:29 AM
ilgdrummer
GS - 1st Gen (1993-1997)
10-11-12 08:29 PM
Live4brew
13
02-28-12 07:38 AM
ALLWiTE2JZ
SC- 1st Gen (1992-2000)
07-12-10 10:13 PM
spxChrome
03-17-03 06:04 PM
Quick Reply: gs wont start... new motor
