Is my starter on it's way out...
Old 05-20-14, 08:29 AM
bonesnj0
bonesnj0's Avatar
The problem with the GS starter is how to get to it to replace it . ...
Exactly why I wanted original Motor with rebuilt Solenoid!
I seen to many remans fail. And I for one did not like pulling the manifold by myself it was a PTA.
Most starter failures are contacts Fails anyway.
Old 05-20-14, 09:54 AM
josey88
josey88's Avatar
Yes, I think you are right . That is what I would do when mine goes bad ... I will rebuilt the solenoid and clean up the body real well and perhaps even replace the cooper contacts .
Old 05-20-14, 10:50 AM
kene
kene's Avatar
Originally Posted by Alphaman19
After some research, I'm going to get the starter rebuild kit as the most likely problem seems to be that the copper contacts inside that starter are just worn out/corroded inside the starter itself. (Why replace the lamp when you just need a new bulb New Starter: $600+ | Starter Rebuild kit: $40
Removing/replacing doesn't seem that difficult; just time consuming. I'd say if you've replaced your own abs unit and or valve cover gaskets, you're qualified to do this job yourself.
I used the kit to repair my starter 5 years ago at 185,000 miles, I am at ~220,000(?). And its still running strong. Once you have the starter out its easy. I did not have to remove my intake manifold or anything of that matter. It was a pain to maneuver the starter out once unbolted, but it was doable on my 1st Gen GS300.
Actually.. I have a spare starter for a 2JZGE. It came from my imported supra motor (~ 67K miles).
I had requested to keep my original starter as I knew what condition it was in because I rebuilt it.
The one I did not use is OEM Toyota japan.
Here is the pic link:
http://s389.photobucket.com/user/maj.../2JZGE%20parts
for $40 would you be interested? I can try to get US postal service flat rate shipping for $8-$9. let me know.
I figure it would be easier for you to 1) test this item outside of the car, 2)rebuild this item with kit (or use as is if it tests good), 3)then re-test before installing.
I think this would save you some down time.
Just trying to help a fellow member.
Old 05-21-14, 08:09 AM
bonesnj0
bonesnj0's Avatar
40 is Real cheap!
GSmamba
05-01-18 05:48 PM
supra9398
Performance & Maintenance
04-27-17 11:15 AM
jerryparks
08-01-12 12:24 PM
OneJay
21
08-15-11 03:24 PM
sockfocks
Maintenance
06-17-06 07:06 AM
Quick Reply: Is my starter on it's way out...
