2jzge valve replacement ??
So I finally got my car put back together from doing a tt head gasket only to find out I got 2 bent valves. So now I'm on the hunt for some oem replacement valves. I'm not going to build the head so I don't need anything aftermarket. Just going to replace the individual bent valves. I may also replace all the valve seals due to being na-t with 180k on the clock. I've already replaced the GE head gasket with the GTE TT head gasket and ARP head studs. Just looking for it be reliable at 400whp. Any good sources for oem valves other then from the dealer? Also do you think I can reuse the head gasket since it has only ran for 2 mins with it on? Been torqued down on the head since Thursday of last week.
