need answers to oil in my radiator?
been a month now
Doesn't over heat
temp gauge works fine...
No smokes..
ac cold
heater hot
Drive great...
fans kicks on
But there's oil in my radiator? and this is my daily! some days i drive for an hour. No symptoms of any issue. Im asking this because, tomorrow i will be driving it 6 hours straight or maybe not depends on what i hear from ya!
thanks fellas!
Doesn't over heat
No smokes..
ac cold
heater hot
Drive great...
fans kicks on
thanks fellas!
i would double check and make sure its not transmission fluid as the tranny cooler is part of the radiator and with age,mixes with coolant from an internal crack.
when this happens its bye bye tranny-happenned on my 99 4runner
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Our gs have an automatic transmission most likely the problem is the oil cooler inside the right expantion tank on the radiator. It's probably leaking transmission fluid inside the radiator as you stated oil on radiator. Pull out and check your radiator and have the oil cooler pressure checked.
well i had taken the radiator out... i try to cover one side of the oil cooler passage and blew in the other.. no sign of leakage.. or does it involve a whole lot more pressure lol.
been a month now
Doesn't over heat
No smokes..
ac cold
heater hot
Drive great...
fans kicks on
thanks fellas!
Doesn't over heat
No smokes..
ac cold
heater hot
Drive great...
fans kicks on
thanks fellas!
I know when I was changing my timing belt I had to take the radiator out to make room to work. Since I was going to put fresh coolant in the car and do a drain and fill on the tranny, I drained the radiator fluid into a container. I also disconnected the hoses to the tranny cooler in the radiator and let the approximately 2 quarts of transmission fluid drain into the same container. The fluids from the radiator and the fluid from the transmission were very close in color. You could see a difference in the density. The tranny fluid floated on top of the coolant but both were red.
I would think that after a six hour drive you would see some signs that your oil cooler is leaking. I would think that you would find coolant in the tranny fluid and vice verse (which you said you have seen). Since most transmissions are extremely sensitive to contaminated fluid, I would expect to see performance issue. Bottom line, radiators are cheap and very easy to install. I broke the upper radiator hose neck on my radiator. I got a new one on eBay last week for about $60. If it concerns you that much, put a new one in, if for no other reason than the peace-of-mind
saephanh12
03-26-14 08:53 PM
