HID fog light kit troubleshoot
04-12-14, 04:00 PM
Hi,
I tried to install the HID kit for my 98 GS300. But there is no power. I tried the same kit with low beam head light and it works fine. Do I need to add any relay or so? Is there any wiring guide? I tried to search for a lot of options before posting this. I didnt found a single write up for second generation GS. Please help me if you can. Thanks in advance.
04-12-14, 04:41 PM
Flip the big orangish brown connector that the aftermarket fog harness connects into, it goes in both ways, flip it til she lights up...
04-12-14, 10:19 PM
^^Thanks for your reply. I will post some pictures of the light and kit. I want to make sure that's the right HID kit that I ordered.
04-14-14, 06:21 PM
I tried fogs on mine and would blow the fuse. you'll need a relay harness
04-14-14, 10:37 PM
Flipped the connector and it's working for now. Thank you guys.
04-15-14, 12:01 AM
04-15-14, 12:40 AM
Quote:
Originally Posted by
nezlyfe
You might want to check your connections because you probably have a short somewhere... that said, I do agree that using a relay is a good idea.
04-15-14, 12:20 PM
Banglabhai
No problem...
04-25-14, 11:35 PM
Driver side Headlight fuse keep blowing. It happened 4 times and now none the fog lights with HID is not working. Every time I install a new fuse for driver side head lights it blew right away. Any suggestion guys?
04-26-14, 04:30 AM
Did you have any issues with the headlight fuse blowing before installing the HID kit?
07-07-14, 09:23 AM
No. It was one of the HID kit was bad and kept blowing the fuse.
o7iS250
11-01-14 06:31 AM
tomkirklan
IS F (2008-2014)
12-12-11 12:43 AM
BinaryJay
02-27-10 08:25 AM
AZ06IS350
03-01-09 09:03 AM
Stormforge
11-11-08 10:17 AM
