Squealing sound from under the hood
Old 04-21-14, 12:30 PM
Lveyolfe
Lveyolfe's Avatar
Default Squealing sound from under the hood
Whether its when I start my car, drive it all day or in between, I can hear a pretty loud squealing sound coming from the engine. Someone told me it was my serpentine belt? I'm not exactly sure. Any ideas and cost for replacement would be helpful, thanks!
Old 04-21-14, 01:35 PM
rgarjr
rgarjr's Avatar
belt is around 30 bucks for the OEM one and takes about 2 minutes to replace.
Old 04-21-14, 02:21 PM
armanitran
armanitran's Avatar
maybe it's the sound of all that pu$$y you're getting from driving a GS.
Old 04-21-14, 07:12 PM
tereck
tereck's Avatar
😂😁😀😊☺😃😄😅😆😉😈😈😈 hahaha that's true all the way
Old 04-21-14, 07:24 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Either the belt, tensioner or simply needs to be adjusted. Even though our tensioners are spring loaded/self adjusting they get stuck sometimes. I had the same squealing and my belt looked good still. They just needed to adjust the belt and free up the tensioner a bit. Good luck
Old 04-22-14, 09:32 AM
socal72
socal72's Avatar
Had the same issue last week turned out to be the tensioner and idler pulley. Hope this helps lmk
Old 04-23-14, 09:30 AM
mk2tmr2
mk2tmr2's Avatar
For what it's worth - you can get *just* the tensioner pulley if you don't want to pay $100+ for the full tensioner. It comes with a new bearing pressed in. Simple bolt-on affair. Took me 10 minutes to change my belt and tensioner pulley - and that was with a 5 minute **** break.
RookieLEX
ES - 5th Gen (2007-2012)
06-05-17 11:37 AM
Pescao
RX - 1st Gen (1999-2003)
03-02-09 07:30 PM
dani3l
08-21-05 11:58 PM
BlkGS3
05-25-05 08:59 PM
brendanlim
Performance
08-19-02 01:26 PM
Quick Reply: Squealing sound from under the hood
