Vibrating at 65-70
So i know there are numerous threads on this, but i need some help. Ive replaced both upper control arms, both LBJ, both motor mounts, balanced newer tires, fresh alignment, caster arms are good, and tie rods are good. I now, after everything, have a vibration only at 65-70 mph. It was very minor, but after i replaced the left upper control arm it got a little worse. Vibration is still there when i get on the brakes as well. Is it possible my tires are out of balance after a few hundred miles? I think all is left is the steering rack bushings? but the steering doesn't feel loose at all, if anything it is very precise and actually pretty heavy, like it was when i bought it around 50k miles. Is there anything else I am missing?
I replaced my caster arms, LBJ and tie rods about 2 weeks ago, after an alignment, the car is perfect, free of any shaking, vibration or noises... and I used to have vibration/clunking noise when hitting a bump.
When you look at my old caster arms, they look perfectly fine the bushings were tight, no sign of wear. I'm not sure how you determined that the other parts are 'good', but in my opinion(I'm far far far from knowing anything), there's really no way to tell 'good' from 'bad' by looking, or pulling on it, etc.
If your tires are balanced, check the torque on the lug nuts... I think our GS are that sensitive.
Caster arms were replaced at 70k, so i didn't want to call them new after 20k ha. It could be the lug nuts, as i almost drove away before completely tightening them (my stupid mistake, didn't get out of the driveway before realizing). Ill take a look at those
Switch the back tires to the front . And check
This times two. To make sure it's not tire related, rotate the tires. If you're feeling the vibrations in the steering wheel and after rotating the tires the vibration occurs in your seat, then it's the tires.
They're are so many ways people balance tires (centering collet on the front side, collet on rear and coning the front, bolt-pattern fingers on front) Techs can say they're "balanced" but the tire/wheel assembly may not be set up correctly, which would say its "ok" when it's really not. If it's a nicer machine, you can also check road force, and possible match mount the tire.
Cross off what you know its NOT, and you'll find out what it IS
Try new sway bar bushings...they seem to go bad real quick on the 2GS and its a cheap quick fix... Also the steering rack bushings could be the culprit
The zip tie trick works wonders for some, including me and I've replace outer tie rods, lower ball joints, sway bar end links, new tires, brakes, rotors, alignment, motor mounts, next Monday upper control arms and upper ball joints are going in, I did the zip tie trick on the steering rack, and finally after all that and it's pretty much a non issue, can't wait to get my uca and ball joints in though, gonna be a new suspension, woo hoo!.!.
Try wire brushing the hub and the wheel itself where it meets the hub next time you have them off.
