Led tail lights don't work!
I installed led tail lights, (white stripe on bottom) and everything works.. brakes, turn signals, reverse light just not the lights when you turn on your headlights, (parking lights i think) i dont know whats wrong or what to do and its really annoying, help!!
i just installed my led tail light s too, and they turned on fine. later they went off, i did check the fuse and found it had blown. i did replace it and now when i turn the head lights the led tail lights wont turn on, only if i press the brake pedal then they come on. any wisdom on how to fix this
I'd check the fuses again to make sure they're not blown. If that's not the cause, then recheck all of the connections and ensure they're plugged in all the way. Another question, did either of your taillights come with resistor packs?
sgvdd525
01-24-10 02:30 PM
TJW98LS
11-22-07 12:29 PM
