sunroof issue, wont open.
I haven't used my sunroof since about October... so like 7-8 months... today I tried to open it and nothing, no sound no movement nothing. I was wondering if it could be a fuse [don't know the location] or the switch... or if its the motor.... what would be a good way to trouble shoot the possibilities. Thanks in advance.
Okay so system not operating it's says suspected areas should be:
-S/Roof Fuse
-ECU-IG Fuse
-Sliding Roof Control switch
-sliding roof gear assembly with ECU circuit.
Let me know if you got any questions. If you need any parts I've got it all, I'll sell you whatever you may need for peanuts man.... Just PM me, but have you tried maybe putting some sort of lube around the trim? One that won't hurt your paint, it could just be stuck man... But check the fuse first. I notice when I don't use my tilt in a long time, when I do, it makes a separating sound from the rubber because they've bonded together from heat an all but it does separate.... I dunno just thinking of anything for you to try
-S/Roof Fuse
-ECU-IG Fuse
coug66 (05-21-17)
-S/Roof Fuse
-ECU-IG Fuse
-S/Roof Fuse
-ECU-IG Fuse
