Average cost for tranny swap?
Hey guys, I have GS300 stock. what would be the average cost (parts & labor) & what will i need to swap my auto tranny to manual 5spd? nothing fancy, just for everyday drive.
Thanks
Thanks
probably 3k
r154 w/ jz bell and shifter extension 1000
flywheel - 300
clutch - 300
clutch pedal/master/slave - 250
custom driveshaft - 300
SS clutch line - 60
then probably 1k labor on that
flywheel - 300
clutch - 300
SS clutch line - 60
only mkIII supra's came with r154's over here but they have M bellhousings, you need jz bellhousing, which you can either get here http://www.driftmotion.com/1JZ-2JZ-R...sing-p/dm3.htm or just buy a r154 from japan it comes with a jz bellhousing and usually a lot less miles.
Other option is to go w58 which is cheaper and smaller but holds less power.
It's a good idea to get these for either of the trans before you swap it in.
Marlin Crawler Shifter Socket
Marlin Crawler Urethane Shifter Bushing
he asked for average price. you can get deals on a most of that stuff, labor and trans will be a majority of the cost. or you could do a complete rebuild and carbon fiber driveline and it can cost 10k. just depends on what you want and what deals you can find.
Not to be a downer, but it will definitely freak the stock electronics out if you swap (it will set all of the transmission related codes). You will at least lose cruise control, VSC, traction control, and could fail state emissions testing due to lights and codes.
Are you for real! Eventhough, in FL we do have emissions testing but i wouldnt want to lose traction nor the cruise control. I guess i have to do some more research & thinking to do.
