Is the 01+ GS any quieter inside than the 98-00?
Old 06-05-14, 02:38 PM
wise2k
wise2k's Avatar
Default Is the 01+ GS any quieter inside than the 98-00?
I've owned a few GS300s, one from each year between 98 - 00 before jumping ship to a 2003 ES300.
I read somewhere that amongst the improvements in 01+ was noise insulation. Can someone chime in on that..?
I find myself wanting to get back in a GS but I know that I'm spoiled with how serene/quiet the ES is, but the looks are just bland.
wise2k is offline
Old 06-05-14, 03:59 PM
armanitran
armanitran's Avatar
the louder your car is, the more dominant you are.
armanitran is offline
Old 06-05-14, 04:50 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
not sure what you mean by quieter? You mean road noise rom the tires? My car is loud from the exhaust that's it...
tmf2004 is offline
Old 06-05-14, 08:03 PM
wise2k
wise2k's Avatar
Yes, I mean wind noise and road noise.
wise2k is offline
Old 06-05-14, 08:21 PM
1QWKGS4
1QWKGS4's Avatar
Yep, I can confirm, i have '99 and '05. The '05's is quieter and alot smoother. Its not that noticeable but I would say its at least one level quieter.
1QWKGS4 is offline
Old 06-05-14, 09:04 PM
wise2k
wise2k's Avatar
Thanks, I needed to hear that. I guess I'll set my eyes on the 01+, also because of the side curtain airbags. I'm a single dad and I like how safe I feel for my son in the es300. But again, it looks like it was made for senior citizens.
wise2k is offline
Old 06-06-14, 01:45 AM
tmf2004
tmf2004's Avatar
i had a 97 Es300 as well and that car was smooth as glass... keep us posted... thanks
tmf2004 is offline
Old 06-06-14, 01:57 PM
JLAWS
JLAWS's Avatar
I had a 1999 GS400 and Just got a 2005 GS430. The GS430 is a tad quieter and smoother. The engine 4.3 engine is more refined. Same engine in the LS430 of course.
BTW
*** MAKE SURE ALL THE BODY PLUG ARE THERE** You will hear wind noise if a few are missing. My GS430 had 5 missing!! I pulled the service records and the previous owners complained about wind/road noise. It was checked several times.
JLAWS is offline
Old 06-06-14, 04:46 PM
Lukas99GS
Lukas99GS's Avatar
Well a newer car is more likely to be quiet, rubber door seals are less likely to be deteriorated, but again it depends on the condition of the car too, as well as tires.
Lukas99GS is offline
Old 06-06-14, 04:47 PM
Lukas99GS
Lukas99GS's Avatar
BTW
Could you provide something showing where they're all supposed to be? I really want to check mine.. Also where they may be on sewell?
Old 06-06-14, 09:31 PM
1QWKGS4
1QWKGS4's Avatar
BTW
I don't have any wind noise in my '05.. i'm wondering what body plugs you are referring to?
1QWKGS4 is offline
Old 06-06-14, 10:03 PM
JLAWS
JLAWS's Avatar
See this Thread.
https://www.clublexus.com/forums/gs-...-window-2.html
The rubber body plugs are very flimsy. Over time they fall out. I reinforced the ones that were still there by applying silicone adhesive around them. For the ones missing, I just used stick on aluminum flashing leftover from home repairs. You can get it from most home improvement stores. I cut some small squares and sealed the holes. The tar adhesive is very strong and should be permanent.
Attached Thumbnails Is the 01+ GS any quieter inside than the 98-00?-0959590625139.jpg
JLAWS is offline
MattyG
MattyG's Avatar
No real loud wind noise but I live in a windy place so I know it's there. The GS is a very loud car for tire roar. Lots of it. It is not going to give you an LS serene experience.
My 1996 Camry 2.2 was actually a quieter car in the city and even on the highway!
MattyG is offline
Old 06-06-14, 11:16 PM
1QWKGS4
1QWKGS4's Avatar
My '05 GS is almost as quiet as my '05 LS. It depends on the tire you use..
1QWKGS4 is offline
Old 06-07-14, 06:18 PM
MattyG
MattyG's Avatar
I had Toyo Versado's on the rear last summer. Pretty much new but you could hear them whine. And Bridgestones on the front, quite worn out. That's how I got the car.
Then over the winter I used Toyo Garrits (also came with the car). Really noisy all around.
MattyG is offline
Quick Reply: Is the 01+ GS any quieter inside than the 98-00?
