Where can I get my car key cut
If you already have a master key, you can get them to cut a copy, then program it yourself and save some money
Engine programming:
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.(DO NOT TURN)
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time. At this time the security light starts blinking.
7. After 45 to 60 seconds new key is registered and security light goes off (stops blinking).
8. Remove new key and try starting the car.
Door programming:
1. Start out by locking and then unlocking all the doors with the power switch. Keep just the driver's door open.
2. Place the new master key into the ignition and then remove it within 3 seconds.
3. Now hold the key in the air right in front of your face so the key will get the best reception and then lock and unlock the doors 5 times within a 40 second time frame.
4. Close the door and then open the door.
5. Repeat step 3.
6. Now place the new key into the ignition, turn it to the on position but do not start the car, and then turn it off and remove the key.
7. Press and hold both the lock and unlock buttons on the key for about 1.5-2 seconds and then about a second after press and hold just the lock button for about 1 second.
8. If within 3 seconds, the door locks lock and unlock once then the registration of recognition code was excepted... If cycled twice, the code was denied. If it did not work, try step 7 again.
9. Close the door and try out your new key.
Engine programming:
Door programming:
5. Repeat step 3.
