CEL and lights galore
Knock sensor cel is on. It came about when I romped on it getting on the interstate. Along with that came the VSC, VSC off, ABS, and airbag light. The battery light came on as well but would go off if I didn't give it much power. If I accelerate to hard it comes back on. Battery light goes off if I take it easy. Other lights stay on but go off when I turn the car off. I just replaced the alternator.
Need codes. Did you disconnect the battery when replacing the alternator? With all of those lights on which are non-related systems it sounds like you grounded out the alternator cable and fried some major fuses/electrical components
The airbag and battery light have nothing to do with the knock sensor. Sounds like you have more than one problem.
sounds like its the alternator or battery, make sure the alternator you put in is good and that none of the wires are messed up, what your describing happens EXACTLY the way you say it when an alternator is going bad, but it COULD be the battery as well...
based on the fact that the battery light only comes on when you give it more power, go to autozone have them check your battery for FREE, so you can at least rule that out if its not the issue.
took it to a guy. he said the alt is putting out to much power and it might be a regulator in the alt that is bad and causing this. I'm going to pull it off tomorrow and take it back to the alt guy and see what he says.
at this point I'm just over it. either way I think once I get the alt back on I'm dumping this car like a fat girl I caught cheating.
Age of the battery doesn't matter I've had brand new batteries that were defective. Get it tested its free. And if u didn't get the alternator from the dealer then most likely that's the problem. If you would've gotten it from the dealer and had an experienced mechanic do the job this would never have happened
Age of the battery doesn't matter I've had brand new batteries that were defezeroctive. Get it tested its free. And if u didn't get the alternator from the dealer then most likely that's the problem. If you would've gotten it from the dealer and had an experienced mechanic do the job this would never have happened
Try measuring the system voltage as you are driving. Alternators don't "put out too much power", their output is regulated by the regulator. The regulator could be bad. The diodes could be bad. Also, batteries (through no fault of the end user) do suffer infant mortality. (Such things as rough handling during shipping come to mind.) Anyhow, most regulators seem to be set for 14.1 volts these days. If you don't have at least 13.8 volts, suspect the alternator, the battery or associated wiring. Have the battery load tested, that's the only reliable test.
DallasPaul
07-20-21 09:25 PM
