Considering purchase of an 2000 GS 300
Hi all,
I wanted your expertise as I don't have much Lexus experience. I am considering the purchase of an 2000 GS 300.
-Shade under 90k miles.
-Clean carfax, looks to be 1 or maybe 2 owners. Serviced at a Lexus dealer for the most part when I ran the vin on Lexus' site.
-Found on craigslist, owner hasn't been too responsive but said he will be able to show the car Saturday.
Lexus GS 300, Year 2000, Platinum Series, Silver
New: Battery, tires, timing belt, brakes
Runs excellent. No issues. Mechanically perfect
No accidents ever, clean carfax
Asking less than kelly blue book.
If you see this ad, it is still available
State Inspection Good Thru 04/2016
Following were done all at the Lexus dealer:
75k miles; 5/2012-Replaced both front lower ball joints; replaced both front struts and mounts; timing belt replaced; replaced right front inner tie rod assembly
Last service record was from 6/13 and says DEALER FOUND OXIDATION BUILD UP ON BRAKE ROTORS FROM VEHICLE SITTING- RESURFACE. It's obvious this vehicle hasn't been driven much given the low mileage and likely was sitting a lot. Is this any concern? I will check for dry rot on the tires although they should be "new."
Sorry for the long post, but do you think this car is worthwhile for what seller is asking for it, provided it's in as good shape the seller claims?
He is asking $5500 and appears to be firm. I told him I have 5k cash which seems like a fair offer given the vehicle is not the 400 model and is a '00. Obvious pluses are low mileage and the car looks good in pictures. Owner has no issue with me bringing car to Lexus mechanic for PPI.
No idea about the following, which seem to be trouble items that may need to be addressed in the near future: control arms, AC evap box, brake master cylinder, water pump, serpentine belt, spark plugs?
Thank you!
Matt
Thank you!
Matt
Hi and welcome to Cl...my opinion is, that I think the price and car is great. Since its a used car..obviously u would have to fix or replace something ur self anyways, but its well taken care of.i bought my 2000 gs 300 with about same miles or a bit more and I had to do the brakes and the car is great and no problems. I say take before to late.
Thank you for the replies thus far, they are very appreciated. Anything I should check on the vehicle prior to bringing it to my mechanic so I don't waste money having an unnecessary PPI if car isn't up to snuff?
I Just purchased a 2000 silver GS300 about 3 months ago for a similar price with double the mileage. Mine was also well taken care of at the dealership. I would buy that car in a heartbeat.
Saw the car today, it drove well, tight with solid brakes and alignment was good. Had a couple issues: 1 of the tires is mismatched kumho due to a "blown tire." The others are matching Bridgestone. Paint seems ok, some scratches but nothing too bad. There is a dent by the lower driver side bumper That looked to be sealed but wasn't don't too well; didn't see rust. Interior is good, only really worn leather in driver seat. Everything works on interior including ac (strong), heated seats, all windows and sunroof. Radio works but display does not really turn on--possibly a fuse? Display for each climate control turns on with no missing pixels. I plan to bring to mechanic, does anyone think I should reconsider based on this info?
Thanks!
Thanks!
nobody cares about mismatched tires unless they're trying to get it appraised.
LCD of stock radio on this car is a known issue.
if you hear excessive buzzing/clicking with the vents it's the servo motor-- also a known issue
check the power door locks for motor function-- another known issue
it's a 15 year old car, everything about this car has been documented so search the forums
Thanks!
Thanks!
Based on what you've said, there doesn't seem to be any concern. The mismatched tires is nothing to worry about. If the dent isn't bothersome to you then leave it there or get it fixed. The radio I think you'll replace with a double din in due time. They're very reliable cars.
Thank you everyone for the replies. The inspection proved the car was in very good shape. The serpentine belt and rear brakes needed replacement/work and I was able to negotiable the price lower to accommodate these. One of the smaller lights in the front works when just the DRL's are on but when the larger lights are on too, it shuts off, will have to check this out. Thank you again and I look forward to being part of your community.
JoeyGs99
09-20-18 02:47 PM
