'99 GS 300 AC problem.
Hi everyone, I need help to diagnose my AC problem. All sudden my AC blowing warm air, usually is always ice cold. I check t the clutch ,is engaged, the AC button light is solid green, manuals says if the AC button light flickring that means problem with the compressor.
I bought AC pro recharge kit, before I recharged, I check the pressure of the low pressure with the gauges that come with the kit. The pressure read in the red zone. I didn't continues the prosses to recharge the refrigerant. I'm afraid of overcharging the system. Any idea what is the problem with my AC? I was planning to add freon in the system , I thought low of freon, but since the low pressure in red zone I'm afraid. Any suggestions and help I reall appreciate it.
you most likely have a restriction in the system. I recently did some work on a vehicle (not a lexus) that had warm a/c and was getting really high pressure on the low side as well. Traced the restriction to the condenser (couldn't even blow compressed air through the condenser core). after replacing the condenser, along with a new receiver dryer, flushed out the evaporator core, flushed out all the lines, and then recharging the system the a/c was back to blowing ice cubes. Found out later that the compressor was replaced at some point due to it coming apart, basically all the debris from the old compressor clogged the condenser core. So with this in mind, you might also have a compressor coming apart.
Thanks for your respond.
