are 350z wheels/tires a direct fit?
Yes, I did a search but want to be on the safe side.
I'm able to get a set of 350z wheels with Blizzaks on them for winter use for basically free.
rear/front tire sizes are 225/55/17 and 225/50/17
Front wheel is 7" wide and rear is 8" wide
Any fitment issues or anything special I need to make them fit, or just bolt on and go?
Am I unable to rotate the tires back to front since the rears are slightly wider?
Thanks.
Thanks.
Also the wheels will not be hubcentric, so you may feel a slight shake in your wheel at higher speeds
Looks like I might want to get some hubcentric spacers. The wheels are stock 350z wheels, so I'll look for a 350z wheel > Lexus hub spacer, unless someone already knows of the correct size.
BigVIPness
Wheels, Tires & Brakes Forum
11-05-08 07:07 PM
a4_turbo
IS - 1st Gen (2001-2005)
12-21-07 12:10 PM
