Is it possible that my CEL P0420 is due to 87 octane gas?
Old 12-20-14, 08:54 AM
budmantom
budmantom's Avatar
Default Is it possible that my CEL P0420 is due to 87 octane gas?
I had my CEL come on 2x in the last 600 miles both times it was very cold, I had just started the car 1st time that day, it ran bad and I was using 87 octane gas. The car ran fine after warming up but is it a possibility that I'm getting the CEL because of the fuel?
Old 12-20-14, 11:32 AM
sung35
sung35's Avatar
Scan for the code, then you will know. I don't think regular gas would cause the cel. The car computer will adjust the timing for lower grade gas. It is not recommend however to put regular gas in a performance car. The car was design with high octane for performance purpose. Putting lower grade gas does not save you any money. Your car will suffer from lower mpg, so the cost will balance itself out. My suggest to you is DONT USE LOWER GRADE GAS THAN THE CAR MANUFACTURE IS RECOMMENDED. This suggest is for any car.
Old 12-20-14, 12:16 PM
marshun
marshun's Avatar
well the sticker does say to use premium.
but use the search. youve got reading to do
Old 12-20-14, 12:18 PM
sivikvtec
sivikvtec's Avatar
Check for exhaust leaks if you are getting P0420.
Old 12-20-14, 12:28 PM
brainsurge
brainsurge's Avatar
bad fuel can cause your cel to come on. also can exhaust leaks, bad oxygen sensors or bad converters. drive it with proper fuel, if the fault comes back, troubleshoot.
Old 12-21-14, 03:06 PM
1UGLYGS
1UGLYGS's Avatar
your saving what, maybe 3 or 4 bucks on a full tank?...
like what was said above, never put lower then manufacture recommendation.
Old 12-22-14, 03:38 AM
13loody
13loody's Avatar
I agree that the car is supposed to adjust the timing when using lower octane gas. However, I used to fill with regular gas and would get multiple CELs. After switching to premium, it would go away for longer periods of time, to the point where I now only get it for 2 days out of the year at most. I haven't made any changes other than switching to premium gas so I'm going to assume that using lower octane gas was the cause. Note that the CEL problem didn't disappear right away, but perhaps I should have reset the ecu (i.e. unplug the battery for a while).
Old 12-22-14, 06:26 AM
DMPesso
DMPesso's Avatar
Default 420
a 420 code is 90% of the time an exhaust leak. Do you hear any farting type of sounds when driving? Make sure you get your car checked out for exhaust leaks before assuming it was the gas. STILL, you should NEVER put less then 91 octane gas in this car. It was designed that way for a reason.
Old 12-22-14, 07:42 AM
KeyKeeper
KeyKeeper's Avatar
Originally Posted by DMPesso
Do you hear any farting type of sounds when driving? .
I do....but thats my wife after we have Tex-Mex @ Casa Ole!
GoodRevs
12
01-14-24 01:43 PM
Bobzi
01-23-22 04:56 PM
patrickkv2
06-29-15 07:03 AM
swiftscsi
ES - 5th Gen (2007-2012)
13
08-27-10 05:55 PM
breakb
Performance & Maintenance
03-22-08 01:51 PM
Quick Reply: Is it possible that my CEL P0420 is due to 87 octane gas?
