Seat stuck in forward position
The seat on the passenger GS4 is stuck all the way forward. When I try and move it back nothing happens. I think it may have something to do with a fuse or maybe even bad motor. Is there a way to manually move it forward?
Maybe there is something wedged on the tracks of the slide rails or possibly a bad motor. You can remove the seat very easily. There is a bolt on each corner of the seat. It’s bolted to the floor board. Once the seat it out you can fully examine the rails, the motor are also located under the seat.
Recliner seat does not come all the way back
recliner shaft was stopping due to seat back sponge getting caught while rotating. I cut out some of the sponge and blue plastic piece. Problem solved!!
ahero4all
SC- 1st Gen (1992-2000)
07-01-18 07:33 PM
