Just dynomated doors!
after using brown bread for my trunk. I dynomated all four doors and underpanel where sub is located inside the trunk today. Result is quiter inside the cabin, although not as much noticeble as when I did the trunk last time, it is quieter. Problem is not I am noticing the road noise coming from under the car and engine noise more. I guess its due to elimination of noise from doors and trunk causing noise from under the car more noticeble. Exhaust noise from my borlas is virtually gone other than when I step on the gas. No drone. Has anyone here done dynomat or other sound deading done under the seats and bottom of the car? also how about under the hood? I am thinking about doing the hood next.
Your GS wasn't quiet enough for you?
The other day I started getting kind of upset because my GS4 has some tiny little creaks and rattles when I go over big bumps. But when I started to think about it, 99% of the cars on the planet you would never have heard these rattles because the road noise would have masked them.
In other words, when you make a quiet car, your noise "ceiling" lowers. Everyone knows that. But what a lot of people don't realize is that your ears get adjusted to the noise levels. So that's why the first time you road in your lexus everything seemed so silent, and then after you got used to it, you started to pick up on road noise. Unless they somehow make a car that's literally 100% silent, you're always going to hear some road noise no matter how well sound-deadened the car is.
Just about the only thing that can give you some perspective on the whole thing is by going and riding in another mid-class car. It's only then you will realize just exactly how quiet your car is.
I guess what I'm saying is that sound deadening is kind of like crack... it feels good at first but a few days later you stop noticing the effects and you want more.
Of course my gs is quiet as hell. Just like you said I am used to it and want more tranquility.
I could only hear hum of my exhaust and the people outside when I drive off always looks at my car because of my mean grawl so I know that my sound deadning works. But I am thinking about getting turbo or maybe getting a header or race pipe so I want to reduce the inside noise as much as I can.
Well, like you said MOD-ing is like crack, I can't stop.....
Originally posted by bitkahuna
I heard hell is not very quiet! It will get louder with the screams of former terrorists and Saddam soon.
have you done anything on your car after your trunk and rear seat? you know your are the one that started sound deadning for me. Causing me to spend more money . Well, I am glad though, I have much quieter ride.
you are right bit,
you are right bit,
No, I didn't do more than that yet... one of these days I'll try to put my boatload of Vcomp under the front carpet - that's what I'd really like to do.
How hard was it to do the doors? Any pics?
Thanks,
Paul.
I had it best buy guys install it for me at the same time as I was getting my clifford alarm. So installation was not bad. From what I saw, it was pretty easy to take off the doors. I think I could have done the doors without too much problem if I wanted to. How are you going to put the v-comp under the front carpet? I would like to get either brown bread and v-comp or dynamat with v-comp under the front carpet too. Could you let me know what happens? thanks
steve
steve
Search Function Inc.
You can use closed cell foam under your carpet to make the car even quieter. 1/4 inch makes amazing results. Certain brands of the foam (Insulite) also act as temperature retainers. Meaning that the car will heat up or cool down faster when you turn on your heat/condition and would keep the temperature for longer when you are out of the car. I use the same stuff in my car that Army and NASA uses for wetsuites/low heat insulation and the results are pretty amazing.
Using a mass loader (Dynamat, RAAMmat) on your doors won't do that much for blocking the outside noise but prevent flexing of panels when heavy bass notes hit loud. This also make your SPL go up since there would be less energy wasted on panels flexing.
Try http://www.foambymail.com/ for cheaper stuff.
Originally posted by meanboy
Unfortunately, I wouldn't mind a little quieter GS. Take a ride in a late model LS400 and you'll be amazed. I understand the LS430 is even quieter.
My GS rattles like crazy when the road is bumpy. That's the only thing that disappoints me about it. Well, that and it's not all that quiet on the freeway. My dash, passenger seat, console, and seatbelt housing on both sides rattle. My A pillars seem a little loose too. I am not sure if that's where some of the rattles are. And my dash has a dime size bump in it.
But during the next service I am going to have them keep the car until it's all fixed. That should keep the dealer busy for a while.
EV ftw!!!
Hey Retrodrive,
Just read this post (see below) and I must say you have me intrigued..........
Are you saying that installing the closed cell foam under the carpet, doors, trunk instead of using the Dynamat, Brown Bread is better for sound insulation (reducing engine, road and possibly wind noise) ?
I have been comtemplating getting the brown bread stuff, but am concerned about the weight of that stuff - it's quite heavy if you do your whole car and I am not sure I will like the trade off in performance (by increasing the weight of the car) as opposed to a slightly quiter ride..........
Please clarify this for me..
Thanks!
Thanks!
That is exactly what I am saying. Those two products (foam and dynomat) are designed for absolutely different purposes. Dynomat prevent panel flexing by adding extra weight to it but does very little (comparing to foam) for reducing outside noise. Sound deadening and sound insulation are completely different and work best when combined. The best alternative that had been found so far is laying down some close cell foam, laying strips of RAAMmat under it and on top of it (top layer should be worked with heatgun to almost melting point to stick well to foam). This way you still have lighter car and practically no outside noise.
My question to you is: how do I make the foam stick to the RAMMmat? I tried some 3M adhesive without much luck... I even held it to the RAMMmat for 2-3 minutes.
