02 GS300 ABS/VCS/TCS lights on all the time
Howdy All,
Recently the ABS/TCS/VCS lights all came on, staying on steady. Cruise works fine. In looking thru forums, it would APPEAR that I have a wheel speed sensor bad, or more likely, a broken wire in the sensor harness. I had the rear wheel bearings replaced just before the lights came on. Is there a way I can pull codes to determine what the problem is WITHOUT putting a diagnostics on the car. I thought I saw a post that talked abut jumpering the Tc and E1 contact in one of the diagnostics connectors, but cant find that post to save my life!
I'm getting ready to sell the car to a good friend, and want to get her in perfect condition before I do, knowing she's going to a good home! Any help GREATLY appreciated! Thanks!
they have shops that has a ABS scanner. they can tell you what is wrong with it. Or you can pull the speed sensor out and use a multimeter to see if it has power going through.
Maca1281
04-22-24 01:54 PM
