I would say your VVTI gear has sprung a leak. Just as well do CAM seals and crank seal while you are at it.
Either a seal or the vvti itself. Like Burny stated replace all three seals and either replace the vvti or replace the rubber gasket inside the vvti. Goodluck.
@Alphaman19 - does your oil leak look like this as well? i believe it is somewhat difficult since everything has to be spot on in terms of when we put back the vvt-i cam etc? Correct me if I'm wrong but if it is off by a little I believe it could cause a big headache
