Time for rear differential flush? Suggestions?
I have a 2001 GS430 with approximately 104,000 miles. Was starting to consider doing a rear differential flush but was wondering at what milestones you would consider doing this, how often, should you use OEM fluids or is there better?, and if it's worth doing yourself or taking it to a mechanic? As I believe you have to have a liquid pump in your possession to attempt doing this job. Any suggestions/insight would be appreciated
Hey I see you're somewhat new here, welcome
Dont forget to check out our DIY threads for maintenance like this I found this thread:
https://www.clublexus.com/forums/per...ntial-oil.html
However, the link is broken. But I know of where it was going, this is a good page to put in your bookmarks:
http://bananags.grantham-international.com/
Scroll down and you'll find the DIY for the flush Good luck
4 days of rain is putting my change of the differential fluid off here. Glad I saw the threads before hand. I came across a quart/gallon pump fitting combo with hoses at Oriely auto parts that should help out for $9.
I have done the diff fluid change on my 98 GS4 a few times. I use local Canadian Tire (Motomaster brand) synthetic diff fluid. I'm guessing its rebranded Mobil or Castrol fluid. Been using this stuff for over 15 years in my cars. My '92 Cressida went over 580K Km (360K miles) on the original diff before I sold the car. Never had an issue with the diff. On the GS4 I'm at 375K km and still no noises or issues.
If you need the car the day you do it or next day, I would recommend having the drain and fill plugs on hand. The hex fitting strips very easily. I had to notch a groove in mine first time I did it and use a flat head attachment to the air gun to get it off.
