Step By Step...Removing Steering Wheel on 2GS
Tools Needed:
1.) Philips Screw Driver
2.) 10mm Socket
3.) 19mm Socket
4.) Socket Wrench
5.) Socket Extension
Step One
Use the 10mm Socket to remove battery
Tuck Negative in Safe Area
Step Two
Remove Covers to Expose Screws on Steering Wheel"]
Right Side, Small Circle right above Cruise Control Stick
Left side, has a Big Square shaped cover!
Step Three
REMOVE TWO SCREW INSIDE WITH PHILLIPS SCREW DRIVER!
Step Four
Pull AirBag away from wheel to loosen (Be careful of airbag connector!)
Step Four
UnPlug Yellow Connector behind airbag!
Step Five
Unplug Cruise Control Connector!
Step Six
Use the 19mm Socket with an Extension!
Break the Bolt loose (i locked my wheel previous to this step so i could loosen the bolt much easier)
ANNNNNNNNNNNNND Voila!
I Hope this helps anyone with Q?'s! i looked around for awhile before i just said "SCREW THIS" I'm making my own thread!
This was very easy and i hope i made it easy to Follow
Nice write-up.
Ill add it to the 2GS FAQ (Frequently Asked Questions) and DIY Thread which is sticky'ed at the top of the 2GS forum.
I guess you didn't look in the 2gs freq asked questions.
Its been covered a few times.
https://www.clublexus.com/forums/gs-...ing-wheel.html
https://www.clublexus.com/forums/clu...oup-buy-5.html
but nice pictures.
but nice pictures.
[url]https://www.clublexus.com/forums/club-lexus-vendor-marketplace/49805-update-wood-steering-wheel-group-buy-5.html
but nice pictures.
but nice pictures.
Nice write-up.
Trying to remove my 98 GS4 air bag and got the 2 T30 torx loose, but the air bag seems held by something still. I did a 00 LS bag in the boneyard and was a piece of cake.
Ideas what is holding it? Just pull anyway? Its loose, but hanging on to something still on both sides.
I'm glad that you brought this up because I am having issues aligning my new wheel. When I installed it, it was crooked to the right. I removed it and readjusted it to the left by one spline, but now it's crooked to the left. Do I need to get an alignment and get the toe links readjusted?
Talked to my friend at Lexus and he said you have to pull the screws out of the plastic carrier sometimes.
I'll try again tonight.
No you don't need alignment, and probably shouldn't, because the steering wheel center will be changed. The steering wheel sensor would then need to be rezero'd. May or may not set a code for it (If it does, VSC will disable)
I'd get the steering wheel on properly, not sure how to once it is off, but one spline won't go from left to right, wondering if you went 2. its pretty fine Mark it with a sharpie
You know you are driving it now and it is slightly left, pull the nut and put a dot where it is now, or a line, whatever works best. Remove wheel and install no more than 1 dot or line thickness clockwise one tooth. install nut (not tight unless you want to) and then drive and see. I use my fingers to feel on the steering wheel to column to get a feel for how off (I do my own alignments).
I can't do photos right now, my wheel has yet to come off.... working on it!
Guess I'm just stuck with this for now. I'll tackle it again this weekend.
So I still couldn't figure out how you would mark it with a sharpie and be able to tell, but I carefully readjusted it one spline clockwise. It's slightly crooked to the right again. However it's not as crooked as before when it was going right.
Swapping Steering Wheels
I'm thinking of ordering a replacement wood-rim wheel that comes bare - without any of the brackets and stuff that are attached to my wheel behind the air bag. I understand the procedure for removing my wheel, but I'm wondering how much is involved with moving all the brackets and hardware from my wheel to the new wheel. I assume that this has been done by many members.
