Driver window control doesnt work
Old 05-15-15, 11:01 PM
lvfstde
lvfstde's Avatar
Default Driver window control
Idk if this common but i bought my gs a few months ago. And i noticed I could only roll my window down from driverside. none of the windows i can roll down from driverside but from their own door they roll down. So i thought maybe it was just the controls were bad. so i bought another one from a member on here and still doesnt work... What could be the cause of this?
Old 05-15-15, 11:02 PM
lvfstde
lvfstde's Avatar
Default Driver window control doesnt work
Old 05-15-15, 11:41 PM
tn96dc
tn96dc's Avatar
I know on some cars when replacing the window motors you must hold the driver switch and the particular door your programming either up or down. There are other cars that require you to hold the master switch up for 5-10 seconds for the window you're programming... I'd do more research
Old 05-16-15, 03:34 PM
Mr Jokster
Mr Jokster's Avatar
Check the wiring on the plug going to the lock button on the control, maybe something is shorting out keeping it in the lock position.
Dumb question, but it is in the unlock position right?
Old 05-16-15, 05:10 PM
Mcon
Mcon's Avatar
Also, the heat damaged the control. But do what Mr. Jokster say, check your unlock and lock button first.
Old 05-17-15, 01:55 PM
lvfstde
lvfstde's Avatar
well i know its not locked. ive tried with 2 different switches... but yeah ive been reading about the programming but no1 really knows how besides holding the switch for 5-10 seconds.
Old 05-17-15, 01:57 PM
lvfstde
lvfstde's Avatar
oh ok gotcha i read that wrong hahaha about the lock button. ima check when i go down there since i have to do driverside ac servo...
Old 05-18-15, 03:36 PM
lvfstde
lvfstde's Avatar
yea i cant figure it out...
Old 05-19-15, 04:30 PM
Mcon
Mcon's Avatar
Great, good to know that you figure it out .
scarface85
04-05-21 04:41 PM
snayger
05-24-13 12:26 PM
mrs.baam
02-06-11 12:23 PM
pratik_10
11-07-10 04:31 PM
Downfall75
06-07-08 09:28 PM
Quick Reply: Driver window control doesnt work
