Removing Leaked Oil Around Spark Plugs
I need to replace my leaking valve covers on my '00 GS300. Oil has leaked all around the spark plugs and filled up the "holes" in this inline 6 cylinder. How in the world do I get this out without it draining down into the cylinders? I'm gonna change the plugs at the same time.
Clean up the oil mess before removing the plugs. I got a bunch of paper towels and cleaned up real good, then if you can, use compressed air and blow any misc. crap in the valley of the plug, wires, coils.
iModerate
![Agree](https://www.clublexus.com/forums/images/smilies/iamwithstupid.gif)
Paper towels. Soak up all the oil first. Then spray a degreaser in there and then use a shopvac (not your moms/wifes vacuum) to suck it, and whatver gunk is left behind, out of there.
I HAVE THE BEST SOLUTION FOR THIS!!! HAHA IT WORKED AMAZINGLY! Alright so check it out, you need a shop vac for this so im hoping you have one. What you do is, the shop vac comes with a reducer tip k, which I dont know makes it from like 3" to maybe 2" or something, well what you do is get yourself a 1 foot piece of rubber tubing thats 1" in diam. k, stick it into the reducer, and tape it well so its sticking out and air sealed, worked perfect I was able to stick the tubing directly into and over the spark plugs which ultimately let me such everything out of the ports, worked like a charm.
EDIT! your comment wasnt there when I started my answer dammit lol but
