Totally stumped on this one? Drive shaft wont go back in
Hi all,
I am totally stuck on this one, really need some help!
I took the rear driveshaft/axle off to change the reluctor ring, everything went smoothly.
I am now having a nightmare of a time trying to get it back into the housing on the diff (see pic), only part of the shaft came out and the bearings keep dropping out as I am trying to get it back in, even when I do get it back in it just doesn't mate up properly on one side, I have tried every combination?
How is this suppose to go back in? Surely it just slides in without the need for any hammering?
Does it back in in a certain way?
Only other option I have is to take the piece of the diff that refused to come off by jacking it up at the edge in order to force it to snap off, but dont want to damage the diff?
I spent hours under the car, every single bone in my body will testify to the pains lol
Grateful for any advice guys?
I've never removed the axle from a GS, but I'm pretty sure that you're not supposed to take the Constant Velocity (CV) joint apart to do it. CV joints will only work properly when assembled with the parts aligned as they were when new, in other words with each ball in the cup originally matched to it.
You have a one in six chance of getting that right and it would be a LOT easier to do that with the short half of the CV in one hand and the axle in a vise.
I suggest you find out the RIGHT way to remove the half of the CV joint that's still attached to the differential, remove it and reassemble the CV joint. Then reinsert the entire CV and axle assembly into the diff, again using the proper method.
P.S. You might want to mention the model and year.
Thanks for all the replies guys and for the diagram.
Managed to solve the puzzle, had to take it inside and figure it all out, managed to get the cap off the diff and cleaned it all up.
It was really fiddly but basically you have to match up the small ended stars with the bigger markers on the cap/housing.
I will try find a diagram and post so it will help others.
Never ever take that shaft apart like that if you dont know how to repack it all
Thanks for all the replies, much appreciated.
Have just mocked up a quick diagram - Basically all the outer large lips marry up with the smallest edge on inside star, if it jambs then lift it out a little and play around with it, you will get there in the end - just simulate how it would sit on car and make sure it moves in all directions, double check all this before you pack it with grease.
Rmg93SC
Performance & Maintenance
09-17-17 11:26 AM
Overclocker
30
10-13-02 10:17 PM
