creaking noise from front end
So I changed my rotors and pads (front and rear) caster arm bushing, ball joints and outter tie rods.
Symptoms: Creaking while braking, clunking when hitting bumps occasionally, clunking/creaking when i roll from a stop. All from the front passenger side.
Thoughts: Could all of these symptoms be cause from blown shocks? I know my fronts are toast, just been to busy to fix them. I've had issues when installing the new caster arm bushings as well, was getting clunking noises while stopping and still get it when I slam on my brakes, may just run OEM bushings.
thoughts?
thoughts?
I currently have the same issue after changing my front brake pads...I assume it's my wheel bearings that's going bad because when I put the brakes on, rolling to a stop, I hear a creekIng noise...I'm going to change my wheel bearing soon and I'll let u know if that was the problem.
Check this post out. vipxjunky, I think you have the same issue as me. I changed my wheel hub, bearings, and seal in the driver side and that cured my issues.
https://www.clublexus.com/forums/sus...ake-noise.html
Luda, I think you should have posted this in the suspension section. You may get more help there.
oh my lord, Agent$mith I cannot believe how bad that sounded DAMMM!!! I would have gone crazy... glad I know the noise now for future ref. Now, OP here, does your car sound like his video?!?!
I think the noise is from my caster bushing. I replaced both with PSB bushings and still got a noise on both sides until I really tightened them down.
Thats the only thing that makes sense because the noise happens when I go over a bump AND when I release or step on my brakes hard. The sound is like a clunk.
xknowonex
Suspension and Brakes
02-06-08 02:41 PM
