Help! tried installing a aftermarket deck and My battery won't hold a charge
Talk about a mess. So I had a sub and amp that were hooked up to my 1999 GS 400 but I insisted on having a friend take out the cd player and install (or try) a aftermarket cd player so I could hook up 2 subs and a different amp. Needless to say dude did a number on the wiring and when I seen the mess he made totally made him stop and at that point my heat wasn't working and my car had to be jumped In order to drive it.(Not a problem with anything before on this car) So I had someone else try to fix his mess and they got heat to work but the car still won't hold a charge.for a minute the blower motor even ran after car was shut off...something is drawing all power from my battery...ive changed fuses I've changed batteries..had two other people tell me they tested my alternator. It's fine and has to be electrical. I didn't have any problems until he took the cd player out and messed with the wiring. Needless to say I don't know how to fix the problem. Can't afford to take it in . Hoping someone out there can help me out.
well you didnt do the install, you had someone else do it. so this makes me think that i dont think youre up to the task of finishing the install correctly.
take it to a radio/sound system shop. they should sort you out. also, dont go for the cheapest ghetto shop. theres a reason theyre small time.
